Results 1 to 4 of 4
Thread: Home made C.A.I
    VY SV8
    Sep 2008
    Wink Home made C.A.I
    i made my own C.A.I the other week to suit a 99 vt, went down to the local hardware shop 90mm pvc pipe, a 90mm wire mesh adaptment to suit. cut a hole in the airbox and voila 27.50$ cai. Just wondering if leaving the stock intake pipe on the box would make it perform worse then if i just had the 90mm pipe getting air from below the engine. Next door neighbour reckons that it would be minamal as the larger pipe and fact that it is having air forced into it would push any warm/hot air from the stock one back out, i have done a few small mods latelay and have noticed a differnece in performance however i cant be sure that it was because of the cai. Any thoughts would be appreciated.
    ( i can post pics if you like but it like all those other diy cai you see, actually got it off this forum)
    cheers
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by Robbo5390 View Post
    cheers
    Should be fine to leave the OTR pipe on it. It wont cause any more or less of a restriction.
    Might want to get a dam good filter though (not a K&N) for all the greesy dust that gets sucked up.
    Rain shouldnt be an issue as it takes a fair bit for water to climb that far.
    Personally I couldnt do it myself as I live in the country and theres many dirt roads. Not a bad highway or city mod.
    VY SV8
    Sep 2008
    [QUOTE=Ozzie;1143681]Should be fine to leave the OTR pipe on it. It wont cause any more or less of a restriction.
    Might want to get a dam good filter though (not a K&N) for all the greesy dust that gets sucked up.QUOTE
    LOL, i installed a k&n when i fitted it, i mainly do suburban driving so it should be fine. Would be nice if i could run a pod filter into the stock airbox though. Any ideas on how that would work?
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Yeah i've set mine up as best as I can for country roads.. Threads here.
    K&N filters are great but they dont filter the micro dust too well.
    Also heres my pod setup to give you an idea.
  1. What do you think of my home made pod box cai?
    By vnv8driver in forum V8 Development and Modification
    Last Post: 20-05-2008, 05:20 PM
  2. home made caravan
    By shonky12 in forum The Pub
    Last Post: 19-03-2008, 06:25 PM
  3. Home made cai
    By SKNOT9 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2008, 04:10 PM
  4. home made bullbar vs
    By ringfeder3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2006, 10:04 PM
  5. Home Made intake
    By Phantom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 06:41 PM
