Results 1 to 6 of 6
Thread: Voot Voot noise & Vibration when doing 100kph
    VX Executive S2
    Apr 2009
    Default Voot Voot noise & Vibration when doing 100kph
    Hi, I have a VX Commodore Series 2 2002 and when I'm doing 100kph I get a voot voot noise coming from the front. There is also a slight vibration every time it makes that noise. When doing that speed and going around a left hand bend the noise goes away, but then when it straightens up noise comes back again, then when going around right hand bend noise does not go away. I have put in new lowered spings, shocks, radius rods & bushes, control arm bushes and I changed the left front wheel bearing hub and the noise is still there. any ideas on what it could be?? Should I possibly change the right Front Bearing hub as well??
    vx s pac
    Nov 2008
    G'day mate, i have a vx commodore too, and i had a vibration and stuff at 105ks + and i took it too holden and it ended up being that my crossmember had moved a tiny bit.
    VX Executive S2
    Apr 2009
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Check that one (or both) of your engine mounts have not sagged, causing the sump to vibrate against the cross member!
    vx s pac
    Nov 2008
    Smile
    sorry for the late reply. But no it didn't need replacing. They just losened it off and straightened it up.
    VT EX S1 3.8L
    Jan 2006
    Quote Originally Posted by Stoker View Post
    Check for grease spray around your cv joints could be them
  1. Knocking/Vibration Noise @ Low Revs (VS Auto)
    By D34N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2009, 12:26 PM
  2. Vibration noise ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2008, 01:04 PM
  3. clunking noise and vibration
    By igs_rodino in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 01:31 AM
  4. vibration noise on take off
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 07:36 AM
  5. 0-100kph
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 10:23 PM
