Hey.
The airbag light stays on for a while when I first start the engine in my 2000 VX S Pack Manual Commodore. I have taken it to a mechanic and he scanned it with the tool, and no errors appeared. He reckons I might need to replace the airbag module. The light doesn't come on when you turn the car off and then back on like 10 mins later. (eg turn car off, go into shops, come back start the engine and it's not there.) Could that be the reason he didn't pick up any errors?
I've read up about them and they are not cheap.
Just wondering if it's worth taking to Holden to see what they can do and whether they can help me.
Cheers,
Chris.
yea same with me...mine stays on all the time!
is your drivers seat in good nick??? My VT light came on once and it ended up being from a sensor in the seat
there is some sort of fault i had a friend with this problem they took it to holden and they replaced a wire, i think it was a common fault or something as it was free. but many will charge.
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
I had the problem of the light staying on on the dash. Turns out it was the clock spring snapped in the steering column (very common over time). Cost nearly $400 to get fixed because they have to remove the airbag to fix it, and scan the computer for the fault.
my car just started doing this.. i wouldn't really care if the tune didn't happen everytime i started the car lol..
So what do you recommend? Take it into Holden to source the problem and then when the problem is identified, buy the part number and take it to the local mechanic? Might turn out a bit cheaper.
that light is for ur air bag plus seat belt pre tensioner, mine does it aswell, i was told to get a new seat belt pre tensioner as they can set them selves of after time causing this problem
majority of the time, the pretension shorts and sets it off..
take it to someone with the proper scanner an have the code deleted
First step to remove airbag without deployment .
Step 1. Remove NEGATIVE battery terminal. wait 1 minute before proceeding.
the reason is that the Airbag system is still active for up to 1 minute after the battery is disconnected. also when handling the airbag no not face the airbag towards yourself. eg Holden logo away from your body.
I took it to a mechanic and he scanned it and he said no errors came up. Could this be because the light only goes off when I first start the car, and the car was driven into him?
MY RIDE
as above if the car does not chime like you have left the handbrake on then its just normal. if it does chime you know there is something wrong as there should be a code if it does chime and no code there is wiring fault most probably.
It does chime about 3 times and then it goes off. This only happens when I first start the car. eg if I go to the shops and come back to the car and start it up it doesn't happen.
Aiseesoft DVD Converter Suite is a professional combination of Aiseesoft DVD Ripper and Aiseesoft Total Video Converter.
Download this best DVD Converter Suite now.
Key functions and features of this perfect DVD Converter Suite:
(1)Convert DVD and any video/audio to the various video/audio formats
Converter Suite software could easily convert DVD and any video to the various video/audio formats such as MP4, H.264, AVI, MP3, WMV, WMA, FLV, MKV, MPEG-1, MPEG-2, 3GP, 3GPP, VOB, DivX, Mov, RM, RMVB, M4A, AAC, WAV, etc.
(2) Support almost all popular portable players
Aiseesoft DVD Converter Suite software can convert DVD and video to all the popular devices: PSP, iPod Classic, iPod Touch, iPod Nano, iPhone (3G), iPhone, Zune, Zune 2, Blackberry, Nokia, Creative Zen, Sony Walkman, iRiver PMP, Archos, PS3, Apple TV, Xbox, iPAQ, Pocket PC, Mobile Phone, etc.
(3) Easy and powerful editing function (Merge, Trim, Crop)
Aiseesoft DVD Converter Suite software offers powerful editing functions such as merging multiple DVD chapters, titles or different videos files into one file, trimming any clip of video or DVD, cropping video size and so forth.
1:Merge multiple DVD chapters, titles or different videos files into one file.
2:Cut any clip of video.
3:Crop Video Size.
(4)Capture your favorite image
You can capture your favorite video image only by clicking the “SnapShot” function and the picture will be saved.
(5)Support Preview
(6)Fastest Conversion Speed
It has a >400% conversion speed and a short while your conversion will be finished.
(7)Easy to use
Aiseesoft DVD Converter Suite is very user-friendly and easy to use. Only a few clicks to complete the conversion with supervising the whole process on real time.
The Codes are logged in the airbag module.specialist Equipment is required to diagnose airbag faults as they are specific faults to the airbag unit.
i would be careful whilst driving and take the car to a holden dealer as soon as possible, as if the chimes come on it means there is a fault, but its an intermittent fault so its probably a faulty ground or faulty connection somewhere.
Also, I've noticed that the colder it is, the more times it beeps and the longer the light stays on.
what i hear is that when the light comes on then the chimes start the air module is do a self diagnostic check on the system and if the airbag light stays on then there is a fault within the airbag/system thats from a sparky i know
ok now u have me worried lol.. bout 10seconds after i start my car everytime without fail it will chime and the airbag light will come on.. it won't blow up in my face while driving will it? or not work if i have a crash?
my sparky told me there is only a problem if the light stays on constanly then there is a fault within the airbag because my calais is having the same issues
My airbag light used to come on, so i got my brother to clear it with his scan tool, would stay off for a week or 2 then would come on again, so just keeped clearing it, and its beens a good 3-4 months since he cleared it last and the light hasnt come back on yet..
right old pain in the ass the connectors are. i keep knocking mine everytime i drop my ciggie lighter down the side of the seat 60 bucks to reset it everytimebut usaly i get it thrown in when i get a service done at holdens.
