Results 1 to 23 of 23
Thread: help no illumination of ac buttons headlight switch.
    VL V8 & supercharged VX
    Nov 2006
    western vic
    Default help no illumination of ac buttons headlight switch.
    hey ppl ive reasonly put fog lights in and when i finished putting the switch in all worked, till i turned the key on and there was on illumination of a/c buttons to the headlight switch. gear shifter and dash cluster are fine.
    what to check????
    its a vx s .
    cheers
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by blueV8vl View Post
    what to check????
    its a vx s .
    cheers
    I'd say they are blown, they all run off the same fuse.
    One day ALL the globes in our VT's A/C controls blew. Don't be surprised when Holden ask $12 each globe, especially when the salesman told me they will only blow again. I decided to solder in LED's instead.
    Power is measured in DECIBEL
    Nov 2006
    western vic
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    what fuse is that one mate??? just to check it out before i rip it out.
    Fuse #11 under the steering wheel. should be brown 7.5A
    VX Lumina
    Sep 2007
    yea, when u pulled ur dash out to fit the switch u might have bumped the globes and thats all it takes, i had to replace all the globes in my a/c controls, not a cheap exercise
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    yeah this is a fault with the controls and the Lights they used, they are so damn expensive, i had all of my AC lights out. so i am going to just Solder LED's into the boards or go to somewhere like autobarn and see if they are cheaper there.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    The Ac lights are changable. A T5wedge size with a T5 globe (although i think VX is T2)
    The headlight switch globes are T5 and are soldered in.
    Nov 2006
    western vic
    yeah now its only my a/c lights gone. they look not blown either. so they are changeable like narva lights prob have them.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    The AC globes need 2 b wired 2 the original globe holders themselves
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by wrx884 View Post
    thats not to hard to do lol. thanks for that i would of soldered them straight to the board.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by fitz_vt View Post
    thats not to had to do lol. thanks for that i would of soldered them straight to the board.
    I think wrx884 was meaning if your replacing the globes, they need to be soldered back into the holders. But if your putting LED's in there you can solder straight to the PCB, each LED needs its own resistor too. I have done the A/C controls, waiting on my shipment of LED's to arrive to finish the rest as the PWR and power window switches have also blown
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by vn6pwr View Post
    ah ok.
    for LED's i would need my choice of colours.... and then the resistors to match. what voltage at the stock ones ?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    ah ok.
    Stock globes run off 12v. You need to get that down to about 3.5V depending what LED you use. I used 300ohm resistors with 6000mcd blue LED's
    fitz_vt's Avatar
    Nov 2008
    nice i am going for a rainbow dash. blue, red, yellow and orange
  15. #15
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Sounds Different, what LED's are you using for that?
  16. #16
    wrx884's Avatar
    Mar 2006
    u should b calculating wat resistor values that u need from 14V not 12V just the same way u would with audio gear. also 2 play it safe and 2 get the most out of ur LEDs run them at 20mA
  17. #17
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yeah I didn't really research it much and the bloke gave me 300ohm resistors (probably not factoring for 14v) so they are running about 35mA. The spec sheet says 30mA so im hoping they don't burn out. Wont make that mistake again. 350ohm if not 400ohm would be nicer but ill see how they go, got plenty lying around incase they die
  18. #18
    wrx884's Avatar
    Mar 2006
    Actually 35mA is very high even 30mA shortens the life of them coz they r startin 2 overwork them slightly. if u want brighter LEDs use a higher MCD rated LED and u wont have 2 crank them with as much power.
  19. #19
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Will take that into account. Got some 8000mcd on order for the cluster, they come with free resistors but will double check before i start doing anything this time.
  20. #20
    wrx884's Avatar
    Mar 2006
    If u havent used 1 already this will b very handy 4 ya
    LED series parallel array wizard
  21. #21
    Nov 2006
    western vic
    hehe how funny is this the other night i went to turn the switch from cold to hot and all the lights lit up.what the now there all good hehe. thanks 4 all your help..
  22. #22
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Bookmarked thanks
  23. #23
    fitz_vt's Avatar
    Nov 2008
    well i can do got the multicoloured ones, or just different colours i havent really decided yet.
  1. Headlight switch illumination?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 11:48 AM
  2. vk headlight switch
    By holdenmum in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2008, 01:24 PM
  3. vt headlight switch
    By scotto1825 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2007, 11:52 PM
  4. VK headlight switch WTB
    By Lish in forum Swap / Wanted to Buy / Trade
    Last Post: 10-12-2005, 04:16 PM
  5. VS Headlight Switch
    By stockvk in forum Electrical Wiring / Questions
    Last Post: 31-07-2005, 07:34 AM
