HI people i have noticed on the vt/vx rear wheel hub behind the brake disc
there is a STAR BIT SOCKET to remove the hub does anyone know what size
this star socket is any help is great help thanks guys . . .![]()
{H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
anyone. . . . .
bump . . . . .
8mm buddy, you don't need to buy a special bit - get your angle grinder and cut 20mm off an 8mm allen key - put this in an 8mm socket and swing away with your breaker bar or ratchet! Meant I could go to the wreckers and get my own axles and not break a sweat! I now have a selection of allen key 'socket bits' so I never have to curse at an allen head bolt again
**EDIT** sorry, guess that doesn't help with torx bits so much! But the AXLE bolts...
Sai Dai Tae Ma Damies!
