Hey guys just want to know what would be the best injection cleaner to us on a V6 VT? ,or not to use anything ?![]()
remove them and have them cleaned by a pro, they will be ultrasonically cleaned, flow tested and rekitted with caps and o-rings
Cool yes sorry forgot to tell you they are new only done 10000 kms just wanted to know if i do need to put a cleaner in the tank and how long should it be before they need a clean ? thanks mate![]()
I was an advocate on use of injector cleaners a long time ago. Now I've decided these additives are a waste of money. LowVP is right, you're better off having the injectors cleaned professionally and not use any additives in the tank at all.
If it aint broke don't fix it!!!
