Hi all.
As most of you know, I have black altezza headlights installed in my VT.
I've recently installed a 35w H1 6000k HID kit and their too bright for other drivers.
I need to know how to adjust the low beam downward so I dont blind someone and cause an accident.
On the standard VT headlights there was a screw to lower the beam, however on the altezza the screw turns the beam but doesnt lower it?
Any help would be greatful.
Cheers, Ozzie
When adjusting headlights, you need to have them on high beam. They should be exactly parallel to the ground and shoot dead straight. When on low beam they should dip down and to the left slightly.
Measure up to the centre of the headlight and use that as a reference, park about 10 metres from a wall and draw a horizontal, level line at the same height. Measure your centres of the lights and mark crosses through your horizontal line the same distance apart. The way I line up the headlights is to lean a broom against the centre of headlight, then stand behind the car at the tail light and use the broom to find the position on the wall. Then with your high beams on, adjust them until the cross is in the centre of the beam.
But that doesn't really answer you question does it? Maybe you will see the light move when on high beam.
Thanks for that but nah it doesnt andwer my question lol
I know how to level and angle the light but with these altezza ones the actual adjustment screws are different to standard headlights.
I can see 4 screws on each headlight for adjustment (2 are hidden and arent easy to reach)
Yeah theyre a pain in the ass, especially the drivers side one.
»»Resident PIMPSLAPPER««
LOL Rich
Can you use a 8mm socket and rachet?
I adjusted mine lastnight and found it easier than a screwie
Ive got another 55w kit on their way for the high beam![]()
Ive got these too.How did you go doing the drivers one because it looks like you need to remove the battery to adjust it.Then you wouldnt know where they are pointing.
Is it possible for you to show some photos as to what you mean by measuring up the centre of the headlight, and using it as a reference, unless this is just to work out how high the line should be on the wall? If that's the case then I get that, (literally just got it then lol). The use of the broom stick could use some photos if possible? I know it'll be hard cuz you're taking photo's of light, but if you could try that'd be great. I just got new altezza's today and I have a feeling they're probably all over the place...
