Hi,
I have just purchased a VT, during a quick check of everything I noticed that there was only water in the cooling system. My question is, the water seems very clean, so I was thinking of just draining the radiator and adding Tectaloy V Plus straight in, to the correct level and it should mix through.
Would it be ok to do it this way?
cheers
quom
Well, if it were mine i'd drain the lot, flush the block and heater and start again. That way you know exactly what's in there.
Always use Holden coolant 50/50 with distilled water. csiro says its second best in the world and wont eat your gaskets. As juzo said flush out the radiator with the hose first at least. there is a drain plug on either side of the block for draining coolant out. change your thermostat to an early opener and dont forget to get the air out of the system when its full of Holden coolant.
so you don't think it would mix through evenly?
its not hard to drain your coolant just undo the bottom radiator hose and take off the radiator cap. Once its all drained refill with clean water, Run car for untill thermostat opens then drain again through bottom radiator hose and then refill with proper coolant. If I were you though il run a coolant flush through it just for peace of mind.
It prob would mix through evently but you dont know whats inside the block let alone the bottom of the radiator. So its best to flush it completely only take and extra 10-15 min..
Dont bother with the Holden coolant it only regular coolant in a Holden bottle and it doesnt do anything more than what you would buy from repco or supercheap.
Been filling 1000s of commodores including my own SS with repco coolant from work for years and never seen a head gasket go or rust the heads out or stuff water pumps...
BOGAN , do you need the tablets with Repco coolant ?
I have never put them in either and never had a prob with the many v6s and v8s done at work or the ones that i have owned..
My personal opinion is that they are a bit of a con by Holden...
Im draining my coolent as we speak in prepare 4 the heater core change but atm i cant seem 2 find the 2 knock sensors on the block??? ive got the VT cd manual but the pic that shows u the cover plate and sensor is very small n hard 2 tell where it is exactly ne1 able 2 explain where bouts???
Also ive been using the repco coolent and will b again 4 the VT all mechanics ive spoken 2 said 2 use either tectaloy or the repco stuff.
In the manual it does say to remove the Knock sensors to drain the cooling system, I was abit confused. Spoke to the local holden mechanic, he said its a joke, you cant do it with out a hoist, and even then you'd be struggling to pull them out with out alot of effort, and its only bout 100mls you drain out he said.
I didnt bother when I replaced nearly all our cooling system. Personelly I use Holden coolant and the tablets because I know my mums partner will find any excuse to say Im not looking after the car![]()
^^^^^ I would safely say when holden techs do a flush they wouldnt remove the knock sensors either.....
NOW GET THAT HEATER CORE CHANGED OVER.![]()
tabs are to protect ur water pump
iv heard that the tablets are to protect the water pump inpeller from buildup? which I think is crap and iv also heard that the tablets are to lubricate the water pump seal which sounds more true. But still think it is a pull
Holden tablets are a BIG CON!!!!!!
con or not i felt safer using them when i had a VP v6. i don't need them apparently with the VT v8 5.0.
