i have a 97 vt commodore wagon, the problem is that the back right door leaver is not connecting inside and also the child lock is on the door so i cannot get the panel off to fix it. would a coat hanger solve the problem??? or any ideas???
also the front right door the handle leaver does not connect either i have tried to take the panel off but its not popping off any specific way i have to take the panel off after i remove all bolts??
need help asap
thanks
if you are takeing the door trim off look for hidden screws there is a couple there
yeah i got them all but it is still getting caught up the top along the window. should i just give it abiut for pressure
Brute force and ignorance! works everytime, sometimes.
ahk well i will give it ago and see what the outcome is
the door trim slides up and off the door seal. Once you have removed all the screws it should lift off.
also any ideas with the back door or would the coat hanger be the best one??
theres a srew that holds the inner door handle and some also have screw under that again
yes you need to take the window winder off before you can take the door card off, if you have electric windows you need to take the switches out before you take remove the door cards
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
the inside panel is getting caught up the top right side where the pop up lock is located, how do i remove it so i can lift the panel away???
the pop up lock is actually ment to be removed first before taking the door cards off. to remove insert a sharp pointy tool into the centre of the orange part of the popup lock, carefully prise the orange insert from the popup lock slide the popup lock button off of the control rod and remove the door card.
ahhh perfect will get to it now.
finally got into the door and found out the problem. a little plastic joint has snapped.
cheers for the help
