Results 1 to 18 of 18
Thread: Camber Kits
    VX lumina
    Apr 2007
    Callington SA
    Default Camber Kits
    Hi, I was wondering about getting a camber kit for the VX as it insists on scrubbing out the inside edge, which is best 2 or 4 point, how hard are they to fit and what sort of cost??
    Thanks.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    2 point is Camber
    4 point is camber and toe
    Holden recommends for camber wear to use the 2 point kit,
    I would recomment using the 2 point kit because its ont only cheaper but should do the job quite fine.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I would recommend the 4 point kit. If you fit a 2 point then find it doesn't do the job, you will have to fit another 2 point kit.
    Just get the 4 point kit to start with and only do it once.
    I can supply you a Super Pro 4 point kit for $175 plus postage.
    Visit my Facebook page
    VX lumina
    Apr 2007
    Callington SA
    How hars are they to fit?? have no hoist will be doing it with axle stands
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Awkward. The lower control arms have to be removed and then once it's all done it needs a wheel alignment. Allow a day to do it if you have never done anything like that before. Have some help if you can, it will make it easier.
    It's not so much hard, just time consuming.
    VX lumina
    Apr 2007
    Callington SA
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    HA. bridgestone bselect want to charge be 585 bucks for it.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I got a 4 point kit a while ago. While it will not fix the problem 100% it does help alot. Its best to get someone to fit it as Not An Abba Fan said it is awkward to do . Also if you do do it yourself there is no way you can do the wheel alignment without the equipment, and it wouldn't take long for your rear tyres to wear out .
    My kit was $350 fitted and wheel alignment
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by Dayvo View Post
    where was that from dayvo...
    i am gonna guess pedders?
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I'd allow at least 2 days for the job.
    If it is your first time removing the trailing arm assembly, then you will find it difficult. Considering there are two to remove + messing around with bushes (removing/butchering out the old ones) you could run into a few problems.
    Having said that, i just finished changing my trailing arm (lower control arm) assembly for the second time and IMO it gets easier each time you do it, be it taking it out or putting it back in. So by the time you are finished the job you would be an expert on this job.
    Now i just fitted a trailing arm with 2 nolathane adjustable bushes, so it is now (once again) a 4 point setup.
    What i found with that is that it is a bit more tricky. I noticed that my left wheel has a bit of toe in, which i might have to have a crack at straightening up before driving to get the wheel alignment.
    So basically what i'm getting at is that the added toe adjustment can make it more complicated than it needs to be for the application. Would i be right in saying that most, if not all people get these solely for the camber correction?
    Just one last thing to add. Just as I was about to fit the donor trailing arm i noticed that the handbrake lever was lose/able to be removed. This was one of those problems that set me back a bit. It involved having to figure out how the handbrake assembly works (thankfully through investigation on my old trailing arm) so that i could fix the problem and get on with the job.
    So yeah, just thought I'd shed some light on this job to do with trailing arm removal/re-installation and if all goes to plan I will never have to do the job ever again:P
    HSV +6
    Mar 2006
    Mornington Peninsula
    Im interested to know where you got yours done too? So far i was quoted $400 for a 2 point kit.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by fitz_vt View Post
    No way mate .It was from a place called Strutfit in Dandenong.
    fitz_vt's Avatar
    Nov 2008
    damn, it means i would have to drive to Melbourne to have it fitted cheaply,i might suck it up and pay for it here i might ring and get some quotes first.
    HSV +6
    Mar 2006
    Damn thats cheap, Dayvo my camberwear is horrible, how bad was yours before the 4 point kit was put in and how much better is it now?
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by And_ROOS View Post
    mine was really bad. I have FE2 in mine . Since the 4 point kit i have got about 40 thousand kays out of the rear tyres and still a fair amount of tread left.
  16. #16
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    My old vt i had the 4 point fitted, made all the difference. Mine was so bad i destroyed 2 10000 odd kay tyres. Cut about 2mm into the walls. $400 odd fitted, that was pedders.
  17. #17
    HSV +6
    Mar 2006
    Well, then its logical that a few calls will be made this week to pedders and strutfit. Anywhere else i should try?
  18. #18
    fitz_vt's Avatar
    Nov 2008
    i dont have much camber wear, i am yet to see signs on my tyres, they have been on 10,000k's , but had a camber check and shes got a tiny ammount of camber not even 1 point.
  1. camber kits???
    By IGNITIONSV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2008, 07:59 PM
  2. camber kits
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 03:54 PM
  3. Camber Kits
    By miss daisy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2006, 03:55 PM
  4. Camber kits
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2006, 08:52 AM
  5. IRS camber kits
    By BLO350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 08:38 PM
