am going to replace my tension pulleys this week end
and that know one is for the air con pump,
now my air con pump is stuffed and cant be buggered spending the
money on a new one
Q: do i need to change the air con pulley or can i just take of the belt
for it as it don,t work anyway or will it cause problems
With a Gen 3 you can remove that belt. Just means the AC Condensor pump wont be taking power from your engine.
Only problem i can see is a power increase of anything up to 20% by removing the belt.
oh i like that idea (more power)
what about fuel will it use less
On subject does anyone know what measurements belt for the v6 without AC pump?
not sure on the measurements but i can give you a shorter one if your located in s.e. melbourne, my pulley pylon snapped at the pully, needed the shorter belt to drive home from S.A. ive since fixed it.
Moar powaa!!!
thanks anyway vnkid but im in syd![]()
i am fairly sure there is VT's without Air Conditioning, they actually have a different belt, in my gregory's it says that the AC model, has an extra idler pulley, its the one above the air conditioner, so i dont see a problem with just swapping to the NON AC belt.
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
fitz_vt, are you looking at the ecotec motor or the V8 motor? The V8's have a seperate belt just for the air conditioning compressor.
Nope the Holden Ecotec came without a Air - conditioner says so on page 40 at the bottom there is a diagram a V6 w/o air con v6 with Aircon and then the V8
Lol. i didnt read the post properly lol. vt SS duh..... V8 lol.....
yeah i would just remove the belt for the airconditioner it wont hurt anything.
I DO know this. Topic poster has a VT SS meaning a V8. In which case this question is assumed to be targeted at the V8's, in which case they have 3 drive belts. The belt that was asked about goes from the harmonic balancer to the a/c compressor with one tensioner. This belt is not needed.
Therefore there is NO need to replace the belt with a smaller belt. I am fairly sure you were looking at the V6's then. Thats what i meant by my last post.
yeah i corrected my post LOL.i didnt read the info provided properly lol...... VT SS lol its a V8 it didnt come in a 6.........
has anyone run the non ac belt on their v6?
is there any difference noticed when driving? honestly?
Actually... The VT SS was available with a supercharged V6. They are rare but I have seen a few around on the net.
Also I don't see how removing the A/C compressor belt would gain any power increase, the pulley runs a clutch system and when the A/C is not in use the pulley is simply free-spinning hence no extra load on the motor. Surely any minuscule gain would not be noticeable, surely not the 20% that has been claimed in this thread.
Power is measured in DECIBEL
Go to Repco.. just ask for a Belt to suit Vehicle without Air-con, they have them
wow. didnt know that one i thought they only came in a v8 interesting piece of information. thanks vn6pwr.
it is proven that the AC works as stated above on a clutch system when the AC button is pressed on the climate control or air conditioning control panel an actuator disables the clutch, and then the air conditioner works, you will only notice a power increase of about 2% when driving but only if you constantly have the air conditioner on always, if you never had the air conditioner there would be no performance increase, it would purely be a psychological, my car has more power now.
2% if your using it? Are you serious? Go throw on your air conditioning and try flooring it from the lights. You'll find more than 2% power drain to the compressor!
Yes they have a clutch, however have you seen the wobble plate and control valve in them? This regulates the compressor. Why would you have this setup if you needed it to perform in a high drain situation and off only? Instead the compressors work in a high drain, low drain (no a/c on) and off mode. As to when it's actually used i couldn't say. But the compressor does vent gases into the crankcase.
