Results 1 to 5 of 5
Thread: Removing starter motor on 5litre
    VT 5.0L Exec
    Jul 2005
    Albury, NSW
    Default Removing starter motor on 5litre
    hey guys I'm about to change my rear side welch plugs and was just wondering if its only the two bolts on the bottom of the starter motor that I have to remove to take it off?
    also does it just slide out or is it abit more technical than that?
    car is manual too.
    I'm going to change the plugs without taking the engine out, I've been told its not too hard to do and I dont even have to take my headers off!! just the starter motor.
    also anyone know a rough price on brass 1 5/8" welch plugs?
    any advice would be greatly appreciated.
    Thanks!
    Jun 2005
    from memory it just slides out
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Vk wags & Vl berlina
    Nov 2008
    it does just slide out
    but the problems start when you go to do the plugs behind the engine mounts
    Nov 2008
    it does just slide out with a bit of a twist
    the problem's start when you try to get the plug behind the engine mounts
    and about the most you should pay is $3.00 each
    VT 5.0L Exec
    Jul 2005
    Albury, NSW
    the plugs I'm changing aren't the ones behind the engine mount, but the ones about 2 inches behind them. I've had a good look at it and I'm confident that I have enough room to get them out then use a long extension on the socket to hammer them back in from about a foot away where I have enough room to swing a hammer.
    didnt think the plugs would cost much but I've been caught before buying something small and it costing a heap.
    thanks for the help on the starter motor too.
  1. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  2. [VIC] 1998 VT 5litre ~ 10k Cheap - Fresh Motor!
    By Trewman in forum Vehicles For Sale
    Last Post: 25-04-2009, 02:31 PM
  3. Harmonic Balance in Motor/Drive Train in a 5Litre
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2009, 11:01 PM
  4. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  5. 5litre motor + auto + loom + ecu
    By wizza in forum Swap / Wanted to Buy / Trade
    Last Post: 18-06-2006, 08:18 PM
