Results 1 to 9 of 9
Thread: Vt Wagon seat belt info --
    VT Acclaim WAGON
    Apr 2009
    Default Vt Wagon seat belt info --
    Hi All
    My middle seatbelt in the rear on my wagon wont pull out. Have removed the unit from the back of the seat just wondering if there was any tricks to get it working again or should i just be another one?
    Cheers Mick
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    its best not to mess around with seat belts just replace it as if you mess around with the seatbelt you might damage internal components that may make the seatbelt fail to work, being a very large safety problem.
    i'd go with the safest option.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Gen 3 VT2 Berlina wagon
    Aug 2008
    I have the exact same problem in my VT wagon i just bought. How did you get the unit out, i unzipped the carpet and could only see the steel backing on the seat.
    Also, my tailgate won't lock.
    VT Acclaim WAGON
    Apr 2009
    Hi
    To remove i unzipped the back, then took off the top trim piece on the seat then you have to actually pull the seat cushion away from the metal back of the seat.
    The spool is just below the top of the seat where the belt goes into.
    It was held inplace by a nut on a fixted bolt.
    Cheers Mick
    Aug 2008
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by ZXTC View Post
    Hi
    Cheers Mick
    i checked the ADR and Safety Requirements for a vehicle and it is actually illegal to open a seat belt on the grounds to fix it, this means that it is defect worthy, it is in the interest of your passenger safety and your safety to renew the seat belt if its not working properly.
    Aug 2008
    Ok, my seat belt did this to me and i managed to fix it 5 minutes ago. All you do is take the bottom seat cushion out so you can get the where the bottom of the middle seat belt is bolted to the floor of the car. Just undo that bolt and try to let it retract a bit. After that, just start pulling it side to side with some force and the lock undoes itself. Then just bolt it back in and make sure when you fold your seats down that the seat belt has something stopping it from retracting into the seat.
    VT Acclaim WAGON
    Apr 2009
    Hi All
    Just letting you know how i eventually fixed this.
    I thought i would be able to source a second hand unit but found out it is illegal to sell used seatbelts in SA. Holden wanted $165 for a new seatbelt part so the solution was the wreckers sell the whole rear seat with the seatbelt still attached. This was know just a straight swap of the rear seat panel for $88. The plus was my original was missing the external trim piece.
    Cheers Mick
    99 VT Sedan
    Feb 2010
    Hi there
    Sorry to dig up old tread
    But how did you get the seat belt out of middle seat??
    Sorry didn't read whole post
  1. Vt Wagon Middle Seat Belt
    By O'MalleyCat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2010, 07:57 PM
  2. VR Wagon seat belt stuck
    By TEGBOY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2008, 10:08 PM
  3. Info/Pic of a 7 seat setup in VR/VS Wagon
    By m3taL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 08:24 PM
  4. vt wagon centre rear seat belt, HELP
    By grassy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2006, 03:57 PM
  5. VT wagon seat belt
    By mser7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2006, 04:48 PM
