Results 1 to 5 of 5
Thread: installing engine mounts vu
    white vu ute
    Mar 2009
    Default installing engine mounts vu
    hello all, ive just bought some new right and left engine mounts for my vu and was wondering if its a real head f*** putting them in or if its worth doin it yourself. I got qouted 270 to put them in and have been looking around on the net and it seems all you have to do is take the weight off the mounts by jacking the engine a bit, and removing the bolts and repleacing the mounts...
    Im not bothered really bout time. Anyone here done it before?
    vt s s1
    Mar 2009
    Done them on a VT last week.
    Genrally speaking they are not very hard however can be a real pain in the ass.
    First thing ou have to do (which the bitch part) is to crack and undo the top two (i think) nuts on the top side of each mount.
    Reason these are so difficlt is that they are done up very tight and can be very awkward to get anything on there and crack it.
    My boss did them for me so i cant really give you any tips on them.
    Then if u have a transmission jack or if not trolley jack may do. Place it under the engine so its ready.
    Then on the bottom side of the mounts there are another two bolts on each.
    These bolts are mush easier to access and undo.
    Undo them and then raise the jack and engine till its high enough to pull the old mounts out.
    Make sure you take note of how they sit as they only sit one way.
    Place in your new mounts and line all your bolts up and lower the engine then redo all you nuts.
    One tip i would have is that when raising the engine try and place the jack so that it raises it as evenyl as possible.
    This will be much easier when you go to lower the engine back down.
    Some wriggling leavering will probably be required as they can be a bastard to get back down in place.
    ANyway hope this gives you an insight and helps.
    white vu ute
    Mar 2009
    thanks for the reply, I was thinking i'd be able to do it but I was certain there could be some tricky setbacks. Im going to try it this weekend. I have to get it right because i need my car to get to work... wish me luck!
    white vu ute
    Mar 2009
    yea i had a crack at it.. for bout 10mins.. 1 side i can undo piece of piss.. the other has a nice bit of frame or sumthin surrounding it and keeping me from gettin to the bolts... i have a vu maybe its different.
    86VL5spd is offline Repn RB 20-10
    R32 GTS-t 2 Door
    Dec 2003
    Blakeview,SA
    Not too hard to dont, worse case undo A/c Compressor for LH mount,
    if you got access to a hoist piece of piss, i do both in 25mins, bend 15mm spanner does tha trick and no need to removed anything
  1. VT Engine Mounts
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2011, 05:45 PM
  2. VT Engine mounts etc
    By discostuee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 11:53 PM
  3. engine mounts
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 05:28 PM
  4. VR engine mounts
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2007, 10:29 AM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
