Results 1 to 5 of 5
Thread: Transmission?!?!?!?? HELP URGANT
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default Transmission?!?!?!?? HELP URGANT
    driving back from my gf's house, i slowly took off from the driveway then they car died, it was still running but the revs dropped and no matter how far my foot was down it wouldnt move, then it it kicked back in and started moving again then stalled. Flashing on the dash was the drivetrain light and the battery light.
    I have a brand new battery and my volt meter was reading at 14v so i doubt thats the problem. I checked for codes by bridging pins 5/6 on the plug under the steering wheel and only got code 12 (everythings fine)
    My guess is the transmission is slipping?? or is it something else going wrong. I need to know by tomorrow as i really need the car!!
    thankyou in advance for any help
    VT Berlina
    Sep 2009
    Did you end up getting it fixed? I had the same problem, but it also made a really huge bang sound and stalled. It also kept jumping like I was braking on and off.
    I've got a '98 VT Berlina.
    VT R8/VU SS
    Mar 2004
    Check your fluid levels; had similar problems turned out the tranny had low oil level (didnt have the bang though)
    Vt Clubsport
    May 2009
    i had that exact problem the other day, my engine oil was low, put the oil in and then no problems.
    not sure if it will be the same for you, but just a heads up incase.
    good luck.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    yeah i got this fixed i THINK, i put a bit more tranny fluid in as it was a bit low and it hasnt done it since
  1. VL Alternator URGANT
    By sxc_sound in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-11-2008, 05:16 PM
  2. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  3. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  4. vp transmission
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2006, 08:51 AM
  5. Urgant - Oil Temp
    By StealthX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2006, 07:24 AM
