Results 1 to 11 of 11
Thread: Can someone please tell me if this will work "pics attached"
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    Exclamation Can someone please tell me if this will work "pics attached"
    hi people i am changing the rear control arms on a mates vx, and think i may
    have run into a problem, i have checked out the control arms on his car and
    the ones he has got to replace them,there exactally the same except ,
    where the shock absorber bolts up on his one it bolts up from the side
    but on the ones he has got to replace his control arms the shock
    absorber bolts in from the back is this going to be a problem or can you just
    swing the shockie round to the back and bolt it up take a look at the pics
    and let me know
    what you guys think cheers guys . . .
    {H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    does it still bolt up all sweet if you just spin the shockie around cheers mate
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    The second pic looks like its from a Wagon!
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    does the wagon diff fit or not ???
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    its got me stumped im not sure why its different
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    any help is very welcome thanks guys
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I think the key problem is that it is not a sedan control arm. When you buy them from wreckers they usually write 'VT SEDAN' on them, which indicates to me that you may have one from a wagon or ute. So IMO, the advice i would give you is to get one to suit the particular body shape of your particular car.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The rear shock mounting on a wagon is different to sedans because the shockies are mounted at a different angle to enable maximum width between the wheel arches on the wagon If the shocks on a wagon were mounted the same way as the sedans, the wagon's load area would be adversely affected.
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    cheers guys
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    he said he can get a set of VY sedan control arms are they the same as VX im pretty sure they are does any one know
  1. Replies: 59
    Last Post: 04-10-2008, 05:09 PM
  2. Info/pics on vl calais turbo "wogstr"?
    By QWiK747 in forum General
    Last Post: 28-08-2008, 09:05 PM
  3. Post your underhood "battery" pics
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2006, 09:39 PM
  4. Calais turbo's "Yellow BT1 cruise" pics
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2006, 09:54 PM
  5. Post your pics of 6"X9" install on parcel shelf
    By debono55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 03:05 PM
