Hey guys, I thought i had posted a while ago but i did a few serches and couldnt find anything...
so... the issue is... When I have my hazard lights on and then lock the car, the alarm goes off pretty much straight away and then just keeps going (stops after 20 seconds and then starts again)
Is this just how it is? or is there somethin wrong there?
Its quite annoying because there are suprisingly many times that i need to have my hazards on and the car locked
anyone any idea?
maybe this thread should be in the electrical section?
your alarm fitted ( WILL BE AFTERMARKET) has voltage sense so when you arm the alarm and you use power it triggers the alarm
most alarms ya can disable this feature
find out what brand it is and go to a fitter that does this
