Results 1 to 14 of 14
Thread: drive belt
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default drive belt
    hi,
    Just had a bit of an problem with my vx s. We put a new belt on the car it was squeaking so put silicone spray on it stopped the squeak. Ok now come the fun part. Was driving in peak hour traffic and the car stalled. it would restart but wouldent rev past 2500 if you tried to make it rev more it would simply die. got it towed home and part of my belt has slipped of and the torn part of the belt has gotten behind the crank pulley destroying the crank angle sensor. Im ptetty certain that the belt was on properly. ok now the old belt I had on it was a GM 6pk2811 but the new one I put on was ac delco 6pk2815 whats the difference between the 15 and 11?
    any help is much appreciated becuase after I get the sensor replaced I dont want this to happen again
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by Simonn View Post
    hi,
    Toyota did this on the corolla's aswell they revise the belts and make them a little bit bigger. or a little bit smaller, it just means the belt is 4 MM longer i think? not to sure, ac-delco is the same as GM they make the same parts.
    i cant see there would be a problem.
    all you can do is see when you get the new Crank angle sensor.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ok thanks. Im thinking now that either I didnt put the belt properly on in the 1st place or I put to much silicone spray on it + plus its been raining so maybe under load the belt has moved.
    fitz_vt's Avatar
    Nov 2008
    yeah that sometimes happens but i would keep an eye on it.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    As above 4mm lomger.
    But I personally would not be spraying silicon on the belt, unless it states on the can it is for belt slipping. Better buy the correct belt anti-slip spray, ....silicon is slippery, just what you don't want on a drive belt.
    vt s/c spak
    Apr 2007
    sounds like you have an alighnment problem somewhere??
    check ur idler pulleys, for excessive where in the bearinngs, and pulley itself.
    also waterpump, when they start to get a bit dicky, it can throw the belt as well......
    davo.....
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks, ill buy some of that belt anti slip stuff. water pump is brand new i'v checked all the pulleys ext they all seem fine exept the belt tensioner pulley I can feel a tiny bit of play in it. It is brand new through are they ment to have a tiny bit of play in them?
    May 2006
    A tiny bit of play isn't going to be your problem, the 'v' groove pulleys will keep the belt running true.
    May 2006
    I feel that your belt squeel was the belt not on properly, could have been one groove out on one of the pulleys, they should not squeel.
    fitz_vt's Avatar
    Nov 2008
    if it constantly squeals i would check the harmonic balancer as it is the main pulley at the bottom of the engine it can cause a squeaky belt when its going.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks everyone. chnaged the CAS and also the harmonic balenacer and its all seems good not now squeals.
    fitz_vt's Avatar
    Nov 2008
    yeah, the rubber damper in the middle of the harmonic balancer slips a little when its starting to go therefore causing the belt squeaks.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ok now here part two. My old man was driving my car thismorning and he recons he could hear abit of squealing again. When I drove it couldent hear anything although im sure my old man isant hearing things haha. What could be the cause? Iv chnage the belt tensioner, harmonic balancer, water pump has been changed new belt is on it also. Iv checked all the pulleys ext and they all seem fine, What could be the problem?
  1. New drive belt
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2008, 10:51 PM
  2. Drive Belt.
    By Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:49 PM
  3. Drive belt ?
    By BLACK-2002 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 09:38 AM
  4. Drive belt gone?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 11:05 AM
  5. New Drive Belt Noise
    By drob1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2005, 09:28 PM
