Results 1 to 3 of 3
Thread: Rear power window doesn't go down
    VX Executive S2
    Apr 2009
    Default Rear power window doesn't go down
    Hi, I have a VX II 2002, the rear passenger side power window works perfectly from the front controls but the rear switch will allow the window to go up but not down. It's not the switch as I have already tested it, does anyone know what else could cause this.
    My thinking is maybe 1 of the wires is broken and will be getting a multimeter to check them, any other ideas on what could be causing this.
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    Happened to me too. i changed the wires from the motor to the body(through the door to the body pillar). Solder and heat shrink. i also swapped the switches over from left to right to see if it made a difference. I then bought new switches for the back. one was burnt out. sometimes if the switch gets stuck on and it burns the switch. I've seen it in the front and the back switches.
    VX Executive S2
    Apr 2009
    Thanks for the reply mate, I will check those things out
  1. Rear power window switch
    By CMA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-04-2009, 04:51 PM
  2. WTB!! Vic VN - VS rear power window switches
    By Cobez in forum Swap / Wanted to Buy / Trade
    Last Post: 23-05-2008, 08:48 PM
  3. rear power window
    By Equipe VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2007, 05:53 PM
  4. VT rear power window shit itself
    By gunna in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2006, 11:50 AM
  5. VS power rear window cable
    By demenace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2006, 07:56 PM
