hey guys just got a vt clubby n no matter wat i put the ac or the options eg face feet ot wat ever i put it on it comes out at the windscreen wat could be the prob thanks
It might have something to do with the vacuum. Check the thin vacuum hose at the rear of the intake manifold.
MY RIDE
yer it was off but is now back on n still no change
yer the valve is right but still cant control the area everythink is windscreen
standard a/c
MY RIDE
ive got exactly the same prob in my VT Acclaim, there is a hissing behind the glovebox, i assume there is a vacuum connection there? and my fan only works on level 1,2 and 3 when its on max it stops? would the resistor be gone in the fan? time for a new one?
I had this problem on my old car (VP). I'm not sure if VT's have them, but my VP had a long steel rod that is connected to the back of the dial you turn to change it between feet / vents / dash etc. The bit that the end of that clipped into was broken (the little plastic clip down near where your left foot would sit on the footrest.
Originally Posted by wikky
yer i do have a hissing behind the glovebox as well
There is a vacuum hose that runs from the back of the heater control to up behind the glovebox. Pull your glovebox lid off and you should be able to find it. That might be loose or completely disconnected.
yer found prob it was a hose off on the fan bit like said above thanks to all ya help
check ur vaccum lines. the actuator uses vaccum to change the the flap setting so it can blow to the face feet or wateva.
first check to see in the engine bay on the passenger side if all the vaccum lines are hooked up
yeap i found it, behind the glovebox, everything works now except the fan, only works on 1 2 and 3, just turns off on max.
