hey guys i dont have a clue as only just got this vt clubsport 5ltr just wonderin how do i fix this prob error 35 n where do i look for this prob any help would be good thanks
n also the missus got error 47 n 49 n 92 on her v6 n how do i fix these n where thanks heaps
i just dont have a clue on vts vls r more my thing so thanks in advance
According to Haynes:-
Error 35 - Idle speed not correct - too high or too low. There are 10 different possible causes listed. Check leak in PCV or sticking PCV. Check throttle linkage for sticking. Air/fuel ratio too high, restricted air flow, contaminated fuel, air filter blocked.
47 - Manual refers to V6 only. PCM has no 18 times signal from Hall Effect switch.
49 - Not listed
92 - Low speed fan. No feed back from BCM to PCM from engine cooling low speed fan.
The diagnosis and treatment of these functions is complex, but is spelt out in the manual. Suggest you obtain a copy to enable you to work them out properly.
