Results 1 to 10 of 10
Thread: Alternator problem?
    97 VT Acclaim
    May 2009
    Default Alternator problem?
    Hey guys,
    Just have a question. I've got a VT and the other day after work my car wouldn't start, I got it jump started and it was fine, drove it around the same day and it had started fine a few times after that. But that night, it had to be jump started again, and now everytime I go to start it, it won't. I had to jump start it last night, but as soon as I turned my lights on it died again. Someone told me it could be the alternator? Just hoping it is not going to be too much to fix?
    Anyone know if it sounds like it is the alternator? Or just the battery?
    VX 5.7 A4
    May 2009
    It sounds like an alternator
    do you see a battery light on the dash when you drive it
    97 VT Acclaim
    May 2009
    No battery light so thats what makes me think it's the alternator.
    Not looking forward to the cost to fix it.
    VX 5.7 A4
    May 2009
    If you have a volt meter you can test
    see the voltage of the battery with the car off it should be around 12 volts if it is lower mabye your battery is dead
    Then see the voltage with the car on it should go up to 13 or 14 volts if it doesn't that means your alternator doesn't work
    97 VT Acclaim
    May 2009
    I'll ask my mates and see if any of them have a volt meter.
    Thanks for your help!
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Sounds like your battery is just too old or been drained to much to charge properly again...
    Or
    A main problem with the alternators not charging the battery is the Regulator, the brushes wear out and stop the alterntaor from charging. From my memory the Regulator needed is an RE60 type to suit bosch.
    That may be the problem..?
    Ben
    There is no such thing as stupid questions, Only stupid people.
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    lol, mine packed it in last night / this morning... Battery light came on and aftermarket volt meter and factory dash one showed about 11ish...
    Getting it back tomorrow arvo... What a shiet.
    97 VT Acclaim
    May 2009
    All fixed!
    It was my battery, not sure why the light didn't come on though. Got the mechanic to check my alternator though and that's working fine.
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    sounds like a problem i had, thought it was the battery to but turns out when the car wasn't running the alternator would drain the battery
    vr ss
    Apr 2009
    The light will only come on when the alt is buggerd . because it stiil has a charge flowing in the alt light wont come on
  1. alternator (i think) problem
    By defecat0r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2010, 04:12 PM
  2. Alternator problem??
    By gupatrol in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-03-2008, 07:27 PM
  3. Alternator Problem
    By Stiks666 in forum Electrical Wiring / Questions
    Last Post: 03-07-2006, 11:06 PM
  4. VK - possible alternator problem
    By Ozgirl in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-01-2006, 10:13 AM
  5. alternator problem?
    By Stewart1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2005, 07:24 PM
