Results 1 to 5 of 5
Thread: Help With VT
    VX 5.7 A4
    May 2009
    Post Help With VT
    Hello I have a VT 5.7 A4 and i opened my bonnet and i found i cut line at the back of the engine as you can see in the pictures below but I couldn't figrue out what it was so can someone please tell my what it is ? and sould i fix it? and is it important for the engine?
    vt berlina series 1
    Sep 2008
    any more info? is it a bypass hose ? is /was coolant been thru it , does your heater work , follow the 2 ends and tell us or post a pic on where they end up , sorry cant help atm
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It is the PCV hose and is important. Is you car idling high and is the engine warning light on? A new hose assembly will cost around $70 or you can buy a brass Y piece and the right size hose and just repair the broken part but it probably won't be long before other parts of the hose perish as well.
    MY RIDE
    VX 5.7 A4
    May 2009
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It allows the crank case fumes to be drawn into the intake manifold and exhausted through combustion. If the hose is broken, the fumes will escape causing pollution and it will also cause your engine to idle higher than it should.
    MY RIDE
