Hi all, I own a VT SS that has the factory HD tow pack (which apparantely means stiffer springs). Each time I go over a bump the DSF door moves up and down as if loose at the catch. A guy at work mentioned that there is a plastic sleeve on the latch that wears or breaks off allowing the up down movement. Anyone know if this is the case? If so is it a readily available part from GMH? Cheers JR
Dropped in to a local dealer today, says he's never heard of this being a common problem. If it's the door latches, they are $180 each as its a complete unit.
I looked at the striker plate on the door jamb and compared it to a new one. New ones have a black plastic shield over the U section that the latch clips over. My ones are missing the plastic. Perhaps this allowing a small amount of movement.
I have ordered 4 new plates @$8 ea and thought I'll drive in a new pair of hinge pins on the DSF door ($4 ea) and see if this works. If it does, its a fix for under $50, if it doesn't, then its not a huge loss
Try undoing the striker plate a fraction and then tap in in a couple of mil to take out some of the slop
Off topic here but my passenger seat also rattles when theres no one in it.
Seems to be worn somewhere, anyone else have this problem with either seats? and whats a good fix besides new rails?
probably not it would be a little to thick depending on what thickness it is. my front doors are missing the black plastic bits and they dont rattle.
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
the black plastic striker only came out on vx's above so it is a common prob for vt'v
Well i have a passenger side door without the plastic and its starting to rattle.
all my doors rattle. holden manual also mentioned a thin strip (Flock tape) that runs along the top of the door seal. stops rubber sqeaking. i also have the plastic missing from the strikers tho.
Fitted the new plastic coated striker plates today, noticible improvement. the 2 PS and DSR dont rattle at all the DSF needs a slight tweak *I still have to do the hinge pins yet, and adjust it about 1mm up, but it only moves very slightly now, so my advice, invest $32 on a set of new strikers, money well spent.
Now to get that awful factory stereo sounding better......................
gday have the same problem too... dsf rattles when going over bumps in the road etc
is it easy to replace? can it be done by a bit of a newbie like myself?
Must be very common for the VT's to do this. Miine has done it from about 40,000k's. Mine still had the plastic over the strikers untill recently though. Could see from outsde the car that the doors just didn't seem to sit perfectly flush with the rest of the car though. I'm guessign it could be the pins? or maybe just need to adjust the striker?
