I've read this HOWTO post:
http://forums.justcommodores.com.au/...commodore.html
but I only have 1 faulty injector to swapout after some testing by a RACQ mechanic. He said it was easy, but looking at the above procedure I don't think so. I wonder if any injector cleaner would get the faulty one going again?
Relieve the fuel pressure and disconnect the lines from the fuel rail. Take off the plenum cover and underneath will be some bolts, undo them and lift the plenum chamber off the manifold, the fuel rail and injectors will come with it. Just pull out the old injector and push the new one in, use some vaseline.
you lost me after the word "relieve" ive wanted to know this as well
Relieve means the fuel pressure is usually high, you are taking that pressure out to a safe level. This is done by running the car without the fuel pump relay in until it stops, thus relieveing the fuel pressure.
A quick search will show that this has been covered a few ties in much better depth than here.
To relieve fuel pressure, start the car, then pull the relay for the fuel pump which is located in the fuse box in the engine bay. The car will cut out soon after, then go to start it again with the key (it won't start) just to make sure.
couldnt you just open your fuel filler cap?..
Nah it's the pressure in the fuel line and fuel rail you have to relieve, there is no pressure in the tank.
i never bother dropping the pressure just to change injectors. i just put a rag down to catch the small amount of fuel that comes out of the rail when the injector is removed. works fine that way on a vn v6, and a v8. cant imagine it would be any different on the ecotec
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
check out the thread below HOWTO - Replacing fuel injectors and cleaning plenum chamber on VT commodore
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
umm that was a 1.5 year old thread dig just to post the exact same thread that the OP posted.
