I might sound a bit stupid here sorry guys, but im wondering how to i disconnect the as module?
can anyone please help me out, im tryin to do it now. it just wont unplug, has it got clips to undo or wat
You have to pull out a tab on the left of the connector to unlock the plug. I'm not sure if the tab is red or yellow. Mine is red.
MY RIDE
k thanx
that is to disconnect the module under the bonnet on the drive side?
MY RIDE
i have disconnected the plug under the ABS module (orange) and turned the car on but all my dash warning lights are still on.
MY RIDE
iv just done it again the way u have posted it above, but my oil light isnt going off. could it be my PCM at all?
i disconnected the bottom plug of the abs module not the top 1, is that right?
MY RIDE
if your trying to get your ABS light to turn off this won't do it, this is just a check to see if your abs module is working. If you want to rid yourself of ABS (stupid and dangerous) PM me and ill let you know.
But please be aware that ridding ABS is BAD mmmk
