Results 1 to 9 of 9
Thread: commodore idling
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default commodore idling
    gday guys. Seem to have gotten my vx all good now. its had a manifold gasket leak then a belt ripped off and destroyed the CAS. Now while the car is pretty good now when idling I can feel the engine through the seats it dosent feel as smooth as it should. Are the ecotec engines smooth idlers from factory? I'v replaced plugs,leads all filters, throttle body has been cleaned out took it off car to clean it but did not dismantle it, Do you think my IAC vavle may be dirty? Is it just a matter of unscrewing it from the throttle body? and cleaning it and its passage with throttle body cleaner?
    thanks
    Vx S pack m5
    Sep 2007
    keilor down, vic
    VT Calais II,2007 Calais V
    Aug 2008
    The ecotecs idle pretty rough, well mine does anyways, nearly all holden engines have a rough idle.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ok thanks, I wanna clean out my IAC valve just for peace of mind. It just just as simple as unscrewing it from the throttle body cleaning it and its passage then putting it back on? Iv also heard to reset them you need to hold the car ate 3000rpm or something is this also true?
    thanks
    vn and vx
    Jun 2009
    Hey mate, yeah my vx runs a little rough like most V6's i've driven but not as bad as my vn.
    Check for vacuum leaks, just a while ago my vx was running pretty rough and i found a leak in a vac hose at top passenger side of engine. not sure what the hose was for but it ran to the other side of the engine somewhere. When i fixed it, it was running like new.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Simonn View Post
    thanks
    nah man when i did mine i just the whole tb off got some nulon carby cleaner and sprayed and wiped everything out til it was 100% clean put it back on and worked fine
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Vx S pack m5
    Sep 2007
    keilor down, vic
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    They aren't the smoothest idling engine, and a bit of wobble is normal. New engine mounts usually help a lot in an older car, what you're probably feeling is just more vibration being transmitted to the chassis from via the old mounts.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks for that mate seems logical.
  1. Help - Not Idling
    By Rachly in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-03-2007, 05:47 PM
  2. Low Idling
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-12-2005, 02:03 PM
  3. idling rough
    By ken & hank in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-07-2005, 10:30 PM
  4. V6 VN cutting out not idling
    By VN Shane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2005, 06:17 PM
  5. Idling problem, VL commodore, 88
    By Commo1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-02-2005, 02:12 PM
