Results 1 to 10 of 10
Thread: VT stalls on first startup each day.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default VT stalls on first startup each day.
    Pretty much says it all.
    Fairly high kms, country driven 1997 VT V6 auto. Stalls every day on first cold start in the morning, starts up, idles for a moment then stalls. 2nd go with a quick pump of the pedal works fine.
    First attempt will work if you apply a small amount of throttle as you start it up... ?
    Any common problems relating to this? I don't know my VTs unfortunately
    Sam
    WTB: mulberry VN interior parts
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    One problem here Sam is that your having to pump the pedal...
    VT's shouldnt need pumping
    Try turning the key until you hear the pump prime then start it see if that helps.
    Always good to rev it as you stall it too that way the fuel line doesnt take stuff all to prime next time you start it.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I know they shouldn't need pumping they're EFI ..
    I think it happens regardless of whether you give it a while to prime or not.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Firstly clean your injectors.
    a bottle of injector cleaner from your local auto parts store run it through with a tank of petrol, if that doesnt work check all spark plugs and leads along with coil packs too. secondly check the injectors are getting an electrical current and also check the injectors are actually working, thirdly check the CAS as suggested above it can throw random codes that arent logged and cause general shenanigans.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    CoMrAdE MaRx23's Avatar
    CoMrAdE MaRx23 is offline CoMrAdE MaRx23
    VS Executive 1995
    Jun 2009
    Cleaning your injectors with fuel additives or the injector clean cans that clip into the fuel rail, is a BAD idea. It doesn’t clean the injectors properly and you run the risk of completely blocking them with the silt and crap that sits in the fuel rails, that has accumulated since 97.
    Injector cleaner should only be used in your car from brand new. Or remove them completely and get them professionally cleaned and tested.
    As for your starting problem when you finally start the car does the engine light stay on for a while? if so its your ignition slip ring (it's part of GMH immobilizer) its a quick and easy part to remove and re-fit.
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    dude, the problem is only a few things (my opinion of course) the idle speed motor, which at high km like mine it was fairly choked . this motor regulates the air going through the throttle body. its a very small passage for air to go through and gets clogged up when you driving n dusty conditions for long periods. especially if the car was from someone who never serviced the vehicle properly and at the right intervals another is the throttle position sensor. also the fuel filter needs to be changed every 30-40k. give the throttle body a good clean with kero and completly wipe clean before reinstall. this job is easy.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks guys, have been offline for a while.. will check all these things
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be that the fuel system is not retaining pressure properly. Next time you start it in the morning let it prime a couple of times to build up pressure. If this works you might have a small leak in the fuel pressure regulator.
    MY RIDE
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I THINK we may have solved the problem. Basic neglect leads were old and terrible.. I will know for sure in a few days as it was always worst on cold mornings .. also Dad mentioned that holding it at 'start' for slightly longer always circumvented the problem, so I figure leads are a likely culprit.
    New ones are on, will soon see if it's fixed
  1. sluggish startup on VS
    By nickwontlose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 09:33 PM
  2. startup problem?!?!?
    By mr.vt.11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2008, 04:28 PM
  3. SV6 Noisey on startup!!!
    By Co_cker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2007, 09:25 PM
  4. noisy vp startup
    By vp holcom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2006, 02:08 PM
  5. Anyone know what the 9 beeps mean on startup?
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 09:51 PM
