Results 1 to 4 of 4
Thread: VT Drive Belt Tensioner Replacement
    Dec 2007
    Default VT Drive Belt Tensioner Replacement
    I am trying to replace the tensioner in my 99 VT - I can't find the instructions in the Ellery manual. Could anyone post instructions to remove the drive belt tensioner?
    Thanks.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    To Remove Tensioner
    1. Disconnect battery earth lead.
    2. Remove four nuts securing engine dress cover.
    3. Using a 15 mm ring spanner on drive belt tensioner pulley pivot bolt, rotate tensioner pulley assembly anti-clockwise and remove drive belt from water pump pulley. Release tensioner pulley assembly and remove drive belt from remaining drive pulleys.
    4.Remove radiator cap to release any cooling system pressure.
    5.Remove generator assembly, (Alternator)
    6. Remove nuts and powertrain wiring harness earth lead from tensioner bracket lower attaching studs.
    7. Loosen hose clamp and remove heater outlet hose from heater outlet pipe connection.
    8. Remove water inlet tube assembly.
    9. Remove studs securing heater outlet pipe and drive belt tensioner assembly, pull heater outlet pipe out from inlet manifold connection and remove drive belt tensioner assembly.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    very poor design unfortunately, you will also need a new rubber red oring for when putting back the heater pipe. THen you need to top up and bleed the system all over again.
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    i did this today but i cannot get the heater pipe to stop leaking.. i replaced the oring but it still wont stop leaking.. anyone know how to fix?
  1. Drive belt tensioner pulley question please
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2009, 03:40 PM
  2. Drive Belt Tensioner!
    By azzfox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2009, 02:56 PM
  3. Q=how do you change drive belt tensioner only
    By jgrock2020 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2008, 11:40 AM
  4. Drive belt tensioner
    By Spaced in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2006, 09:53 PM
  5. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
