just wondering if i can install a corvette servo in my 4l6oe without dropping trans?
yip its on the outside of the box on the drivers side you need to undo the gearbox mount and wedge the box over towards the passenger side to get the room
Yep, not too hard. At worst, depending on your exhaust set up the drivers side cat section may need to be removed.
The servo will need to be pulled out of the trans and re fitted in stages. Tricky for a 1st timer but doable
VYII Calais L67
I had to assembly the servo while putting in the box because of clearance problems ,the worst part was when that f@#$en clip blew out on a test drive ,it looked like a the car was on fire with all of the trans fluid toasting on the exhaust and I left a trail of fluid that leads to my house about a kilometer long
so if you do it double check the clip even though it didnt help me much
oh ok thanks guys, i watched a how to on youtube n it seemed like it wasnt to much of a problem, but that was with the trans on a table! i have to remove my drivers side cat and replace it anyway, has taken a bit of a beating n has a couple of holes n sounds rattly as.
how much did the corvette servo cost ??
and were did u get it fro
$54 off of ebay
Check out my VP right 'ere!
