Results 1 to 6 of 6
Thread: ls1 vt ss -> 383 stroker ?
    s2 VT SS
    Apr 2009
    Default ls1 vt ss -> 383 stroker ?
    hey all
    looking at buying a 383 stroker kit for my ls1 vt ss
    i dont know a whole lot about this so im just wondering what your thaughts are
    my vt is pretty much stocko engine, only extractors exhaust and a ls1 edit
    so first im wondering if i should even bother doing it to a stock engine or m i going to have to change a whole load of other components in my engine ?
    also would like to know things about:
    power gains
    anymore ups and downs ? if anyone else has fitted a 383 kit to ls1 ?
    and labour costs ? im thinking its gunna be a allot ?
    thanks lads
    VX 383 turbo & VK Royale LS1
    Apr 2009
    South Auckland
    If your gonna go 383, don't use the cheaper kits like COME.
    Eagle or callies stroker cranks are good options, i personally went callies.
    You will need pistons and rods to suit the 4" stroke crank, again eagle or callies for rods,
    Pistons - there are plenty out there and choice will depend on application ie boost, N/A
    But Diamond, Eagle, Ross all good. You will need to specify compression ratio with piston choice also.
    To get the best out of a N/A stroker you will need a decent camshaft and valve spring/pushrod/timing chain/oil pump upgrade.
    Then theres the ARP mains stud kit and head stud kit.
    Don't forget Machining for new pistons etc, balanceing and assembly
    $$$$$ add up fast !!
    GMM CAMMED and STALLED VT SS 5.7
    Sep 2007
    Melton,Victoria
    Quote Originally Posted by robbo000 View Post
    hey all
    power gains
    thanks lads
    just buy a crate l98 or ls3. itll make more power, be better to drive and probably work out cheaper.
    383VXSS is offline 383VXSS
    VXSS
    Jun 2009
    Geraldton
    L98 orLs3 wont make same power as 383 unless modded my 383 has got 450RWHP 335 RWKW(STD T/b,intake manifold) and pulls hard, nice and torquey .It is expensive though and drinks fuel.dont forget clutch if manual or rebuilt box if auto,Heads/cam, fuel systems etc It really does add up but you cant beat the sound of a cranky N/A motor.Good luck its all good fun
    Sep 2007
    Melton,Victoria
    Quote Originally Posted by 383VXSS View Post
    an l98 with a small cam makes 335rwkws eaisly. GMM mototsport do a 550hp l98 for 8000 or so drive in drive out. includes fitting and tune. IMO thats better value for money and will use less juice. cant go past a stroker for noise but.
    carless for now
    Feb 2007
    perth,Western Australia
    this has been covered before all the street commo forum and the ls1 forum and l98 woth a cam is cheaper and can make more power
  1. 355 stroker
    By Heeey!! in forum V8 Development and Modification
    Last Post: 02-04-2009, 03:02 PM
  2. LS1 Stroker?
    By adamc11 in forum LSx Development and Modification
    Last Post: 19-10-2008, 08:03 AM
  3. WTB: 355 stroker
    By weedo_86 in forum Swap / Wanted to Buy / Trade
    Last Post: 07-09-2007, 06:16 PM
  4. f.s: 304/308 - 333 stroker kit
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 21-06-2006, 03:57 PM
  5. 4.2 Stroker Kit
    By Jecs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2006, 08:22 AM
