hi well heres whats happening when i turn the key only the dash lights come on no sound in the engine bay but the ignition relay clicking but nothing else put a new starter moter in it new thing round ignition barrel where the key touches the imobilissor turns off when i unlock car and comes on when i lock it so it cant be the key cause i have read else where about it could be the key i have bridged the starter relay and it cranks over then but wont start its like theres no power to the fuse panel under the bonet i have tested for power and everythings fine help
there are so many post on here that can help you just go look for them ,,![]()
so it cranks? but jus wont start?
wat motor? ecotec?
if it cranks but jus wont start it could be ur CAS - crank angle shaft sensor
i will have to get someone to come out with tec 2 see if it brings anything up i have read all things on here relating to it but still nothing
Had the same problem yesterday.. Disconnect battery terminals and clean. Re attatch and VAS up.
Worked for me.
ill try that just want to get the stupid thing going
