Results 1 to 5 of 5
Thread: eco reset and knock sensors
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default ecu reset and knock sensors
    gday was just looking at my haynes manual and noticed that the ecotec engine have knock sensors. These sensors sense knock or detenation dont they and adjust the timing accordingly? So by using 98 octane fuel would I get a power increase becuase it would be able to run high timing?
    Also is there any real need to reset the ecu?
    thanks
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    running 98 would help STOP detonation if your getting it... but i doubt it will give u any power, definitely not noticeable
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks, Always thought that with knock sensors it adjusts the timing to suit the petrol your using. Anyone comment on the ecu reset thing?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    As don0xer said you won't gain anything if your car is already running properly with no detonation.
    Unfortunately ecotec don't have multi fuel tables to deal with different fuels.
    But what you will gain is far less chance that any detonation will occur at all even under extreme loading like lugging up hill in top gear.
    Also 98 is a much cleaner fuel than dirty 91, far less sulphur and other impurities plus 98 also has some cleaning agents in it.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ahh thats what I was looking for multi fuel tables. So the ecotec's dont have them. I plan to run my commodore on 98 octane fuel. Could you please comment on the ecu resetting any real need to do it after say I install a hi flow panel filter? Also with the IAC valve people say after restting the ecu you need to hold the engine at 3000rpm to set the IAC valve is this true?
  1. knock sensors
    By kendro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2008, 08:25 PM
  2. knock sensors
    By Panama in forum V6 Development And Modification
    Last Post: 28-08-2007, 01:13 PM
  3. oxygen sensors replaced-need to reset ecu?
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 08:16 PM
  4. v8 knock sensors??
    By VNcalais5ltr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2006, 06:27 PM
  5. Removing Knock Sensors
    By jeffp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2005, 08:32 PM
