If I were to get SL's in the rear of my car, and keep the FE2's in the front, would I require a camber kit? I have a Series 1 VX Commodore.
Cheers,
Chris.
i would say so mate. i got superlows on my vx and a camber kit is necessary. but some people dont mind the camber. i prefer to have tyres wear evenly though
iv heard that only series 1 vx need camber kits, apparently series 2 have a different rear suspention setups
As above get a camber kit it'll help get more kms out of ur tyres. n remember the lower u go the more camber u put on the rears.
but would it matter so much if his going from fe2? I've been wondering this too as i have fe2 on my car atm, and want to go lower (all round though).
Sort of correct...
VX1 and prior don't have any adjustment, so to do the job properly you need a 4 point kit. VX2 onwards already have limited toe adjustment, so you can get away with a 2 point kit, but going to a 4 point kit will give more adjustment that what the OEM setup will.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
get the camber kit, mines on sl hd and my 19s lasted 2 months untill it got bald on the inside n started showin wire
