hello im new at this stuff but here goes
i have a 99 vt olympic edition sedan
my brakes keep on warping over time i have replaced rotors i have been to brake mechanics and i cant really get a straight answer people say thats just vt's but then others say its your hubs i have replaced my front sway link bars and the front caster bushes plus the bushes it in the control arm the castor bushes where replaced with nolathane bushes but it has seems it has amplified the shaking i have spent quite a lot of money trying to solve this problem but i dont want to spend any more until i can get a more positive answer
thanks
I must have gone thru 4 sets of rotors if not 5 on my VT wagon over the years I had owned it .
I never had the rear rotors changed only the front. Not sure if it's the way I drive, as some say I brake late & hard..Or just the weight of the wagon going thru brakes..
hey yeah i had a mechanic down the road say try putting RDA rotors and pads on but i want to know if people have had this experiance of this problem i have cross drilled and slotted rotors on the front and there just warping big time the car is getting hard to control with the shaking
A lot of it has to do with the way the rims are put on and the wheel nuts done up. They have to be done in a star pattern and torqued up in two stages. I can't remember off the top of my head what the torque setting is, but around 90Nm rings a bell.
If they aren't done properly they will develop what is called 'built in run out'.
so other words i should try replacing my front hubs and see if that helps
No. It has nothing to do with the hubs. The rotors warp as you do them up if they aren't done correctly, and over time they just get worse.
Agreed.... Also its 110-140nm for the wheel nuts. I do them in two - three stages to keep them well balanced.
Originally we had shit time warping rotors, machinig DOES NOT fix them, so dont waste your money, cheap ones are not worth it. We got less then 100km's out of machining them, and less then 5000km's with cheap rotors (mechanics did this, not me).
In the end I begged for mum to let me fix this, end result 4 X DBA Slotted rotors, with fresh pads, and all wheel nuts torqued correctly and in stages. Now done 45000km's from memory, and only the faintest bit of shudder is arising.
i know it sounds stupid, but i had this problem a while ago and after alot of money on the front end and many stressful bad results it was the rear rotors. it felt like the front and i was damn sure it was the front even most of the mechanics said it was the front. but one guy said to replace the back, so i did and have never had the problem again.
hey guys yeah look i have DBA cross drilled and slotted rotors on front and i have just normal DBA rotors on the back, when i replaced the factory rotors on the back they warped in 1 week after all that i took all 4 rotors off and got them all machined fitted them done the wheel nuts up in a star pattern but did not do them to the NM torque specs i fitted the calipers with bendix general ct the rotors lasted 3 months now the brakes are back to square A
tom 1569 when i brake both the steering wheel and gearbox lever violently shake rattle it actually sounds like the car is rattling to pieces.
The drilled rotors are more suited to a track, and are prone to cracking.
Personelly I'd be running RDA, or DBA Slotted rotors with new Bendix CT pads. Torque your wheel nuts correctly and change your driving style*.
*After a heavy brake, put in neautral and take your foot off the brake so your not resting hot pads in one area, especially when you just slammed them on for that redlight camera. Another thing is to brake early, then for the last 10 metres or so, just roll it out to let your brakes get some air and cool, before coming to a complete stop. There the only things I do differently in the VT and it hasnt come back yet, though mum is going back to driving the VT now so it will interesting to see if the shudder comes back, caus shes a hard late braker and doesnt care much lol.
When you brake, do you stomp on the brakes and leave them applied until you come to a complete stop?
hey not an abba fan yeah look because of the current problem i have i brake any where from 100m or further back the only time i brake hard is pulling up to a amber light changing to red or if im late to work
RDA slotted rotors were going to be my next choice along with RDA pads hopefully see some results
I really dont see why you're going slotted either.
Just go for normal, run of the mill discs. Bed them in properly and take it from there. Dont waste your money on things you dont need, such as cross drilled or slotted.
i spoke to a guy who used to be a mechanic for shacks and said that the vt had these problems as it was the first commodore to come out with bigger rotors and twin piston calipers but what i dont understand is if that were the case then y the back warping for there still only single piston calipers or is it just because there PVR branded
My VX SS has just started to develop a slight run-out vibration when braking, very slight,
it has done 60,000km original pads and discs haven't been surfaced yet.
What I wanted to ask is it possible for a run out to be felt when not braking, I have just put new tyres on my VX and I have had them balanced twice and I can feel a slight vibration at certain speeds similiar to the run out feeling when braking, only slight and on some roads I can't feel it at all, I thought it may be that the new tyres are a bit more sensitive to the small iregularities in the road, hence why I can feel it some times and not others.
I have tensioned the wheels with a tension wrench, not sure if the VX is different but in the driver's handbook it says 100 to 125nm, I did them up to 120nm.
Just thought you might have some ideas on what the vibe might be.
no sorry mate i would'nt have a clue im just starting to think it may be a similar problem in all the new commodores as when my dad had a vy commodore he had slight vibrations whilst braking he also used to have a vp calais that was a nice car never had a problem
Sorry to re-birth this post but I did some experimenting with my personal car which has had 3 sets of discs due to steering wheel wobble when braking. Seems to be more pronounced when light braking by the way.
Anyway, I performed a detailed run-out check of the discs whilst fitted to car. The maximum axial runout on either side of rotor was 0.02mm or 0.0007". Run-out variation between each face (at the same time) was about the same 0.02mm.
I then took the discs off and mounted in a precision lathe and pretty much zero'd the inner mounting face and the run-out improved to 0.01mm. Thats about "two tens of Fu#k all".
The holden specs for disc runouts are about double what I achieved with discs mounted on the car.
Some years (maybe 20) ago, torquing of wheel nuts in a cross-pattern to the correct torque value was more important to prevent brake issues due the the bearing hub and disc being intergrated, however, the design incorporated in the vt's which effectively sandwiches the disc betwwen the bearing hub and the rim should not adversely effect disc runout after tightening. I did try torquing the nuts as unevenly as possible and the runout figures did not change. That said, it is good practice to torque wheel nuts evenly.
I personally haven't had much luck with DBA discs on various cars and as some other have commented, drilled discs are a waste of time unless you race a rally car. The DBA life span seems short IMO and they tend to develop brake squeal issues.
I've had the best run from genuine GMH discs and these are the ones I've tested above.
I fitted a new set of Lucas pads and the shudder was gone. The old pads seemed to have worn evenly which rules out caliper sticking or wear.
Maybe I've previously throw out good discs![]()
VE II SS-V Sportwagon
change drivein style losse cross driled rotors go bak to o.e replacement and do u have a stickin caliper or is the ABS playin up and holden pressure on the brakes???
I'm with Thumpin , i reckon its more often the pads than rotors.
I had shudder on my VS and changed the pads without touching rotors and the shudder was gone.
and for my 2 cents I used Bendix ultra premium brake pads from super cheap auto, about $60. Also make sure you GREASE THE SLIDE PINS on the callipers with the proper grease every chance you get.
Are you referring to the Guide pin bolt? If so that is suppose to have loc-tight not grease. According to the manual they should be replaced everytime, but pffft who does that lol.
I learnt the hard way after losing that bolt and having next to know brakes coming into a red light at the bottom of a hill in an 80 zone![]()
ok cool well i have had all rotors machined lasted for 3 months car does not have ABS and my driving style well thats y they built FORDS to keep ********s out of holdens
do you use the automatic car washes? just asking as they are not the best for your brakes as they throw a stream of water onto your wheels and brakes while there red hot from the drive to the car wash.
