Results 1 to 3 of 3
Thread: how to replace rear side window in cargo bay on a vt wagon
    vt exec
    Apr 2009
    nelson bay nsw
    Default how to replace rear side window in cargo bay on a vt wagon
    Hi All,
    You may have seen on other posts i have smashed my rear lhs window in the cargo bay of my vt, (as you look from back of car), i was wondering if anyone has any pointers as to how to change the glass my self, im very handy but im wondering if i should bother atall any ideas would be a great help cheers guys Tim....
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I had a quick look at mine last week and believe it is just as easy as a VN-VS.
    What you need to do it take the interior plastic off surrounding the window then undo the 10mm plastic nuts that hold the window in place.
    When putting the new window in use some windscreen sealant from any auto place to help seal it. The original sealant used by holden is just foam and starts to leak after some time. You will also require some metholated spirits to clean the surface for a better seal with the sealant.
    It is very easy to do.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    vt exec
    Apr 2009
    nelson bay nsw
    thank you very much sounds doable ill attack it tommoz when my hangover clears out lol
  1. Wet Rear Passenger Side Foot Carpet on Wagon
    By VZ05 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-08-2008, 07:37 PM
  2. f/s: 1X pair of vn/vp wagon side window venetians
    By white vn ss in forum Parts And Other Items For Sale
    Last Post: 11-07-2008, 12:23 PM
  3. Rear driver's side window rattles itself down
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 12:02 PM
  4. buying passengers side rear electric window motor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2005, 12:36 PM
  5. drivers side rear window
    By david41073 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2005, 10:03 PM
