something in the window is scatching it and i want to know what it is so i can fix the problem. its only on the left passanger side and if it helps i have a vx berlina. i can provide a picture if needed to sort of pinpoint the location of where the scratches are.
thanks
I'd say its the same thing thats making it get stuck tbh, Anything that's stopping the window going up/down and touches the window will wreck your tint, Pull the Trims off and see if you can find anything obvious hitting the window.
On the window lip on the inside of the trim, you could have some grit or metal filing etc that is rubbing on it. Take off door trim and check it out.
it could even be the window rubbers as they dry out and get brittle which could lead to scratching the window!
