Results 1 to 5 of 5
Thread: back right power window is getting stuck
    vx berlina
    Feb 2009
    Smile back right power window is getting stuck
    im just wondering how i can fix this. im an apprentice electrician so it probably makes it a bit easier so u probably don't need to go into massive detail although if its needed then yea go ahead.
    thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A bit more detail maybe. Is it random, when going up, when going down, is it in the same place every time?
    MY RIDE
    vx berlina
    Feb 2009
    sorry um well i can control it from the front, but i cant control it from the back and when i do control it from the front it goes reallly slow and sometimes gets stuck and i have to physically hold the top of the window and help it up.
    and i forgot to add that i cant ocntrol the back left one from the front at all but u can from the back.
    i dont know whats wrong and i dont know how to fix it
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    As DanVN said in your other thread, it is probably the same thing that is scratching the window tint, something is rubbing against it. You will need to remove the door trim to see what is going on.
    MY RIDE
    VX Berlina Standard :(
    Mar 2009
    I had a similar issue with my front window and found the plastic runner that moved horizontally on the electric window mechanism split. Hope it helps.
  1. Power Window Stuck
    By 90TTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2009, 12:56 AM
  2. LCD screen stuck on oddometer 3 window VZ Calais
    By hwystar in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2008, 10:14 PM
  3. back power window not going up
    By nickmarlow1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 10:55 AM
  4. help! vn calais power window stuck
    By my vn calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 01:04 PM
  5. drivers side window stuck
    By azza009 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2007, 05:34 PM
