Results 1 to 2 of 2
Thread: VX SS creak and clunk
    VX SS commodore 5.7 m6
    Jun 2009
    Default VX SS creak and clunk
    Hey all,
    I'm new here and need a bit of help. Ive done searches through the site, the web and ls1 forums. no help as yet...lol
    My VX has a bit of a clunk/creak in the front end, you can hear it and feel the vibration through the Accelerator pedal and firewall/ floor pan.
    Its only at low speeds when taking off and/or cornering
    I have replaced the sway bar link pin bushes on both sides, replaced the upper bearing plate and bearings on both sides(above strut) and checked and tightened all the front end bolts i could see. all the bushes "seem" to ok.
    i also had pedders take a look at it and they wernt to sure either.
    i was told maybe really bad pinging, but my plugs seem to be ok and its running fine
    also took a bit of a look at the engine mounts and checked my exhaust for clearance...
    I'm out of ideas PLEASE help!
    Thank you in advance
    I just noticed also if you start the car when its cold with the throttle half depressed it also makes the noise
    ... guess no one has any ideas?
    VT SS Commodore 5.7
    Feb 2009
    Well making the noise stationary with foot on the throttle isnt going to be suspension. Are you sure your engine mounts are ok? Is your exhaust cracked by any chance up around the firewall area?
    Adam.
  1. vz sv6 clunk
    By esp22 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-08-2008, 01:11 AM
  2. front end creak
    By orangewagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2005, 10:37 AM
  3. Creak When Opening Drivers Door On Vr Statesman
    By sik_vr_statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 02:01 AM
  4. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
  5. Clunk
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2004, 08:14 PM
