Hi guys,
I have just bought my first commodore, a VT 2 Exec
It's going to be a bit of a project so i'm sure this forum will become a regular haunt for me
Anyway, I was crusing around last night and noticed I had no taillights!
I want home removed the tail light assys and found no bulbs!
It turns out that both tail/brake light harnesses are broken (the plastic bulb receptical)..
Does anyone know where I can get 2 replacement harnesses today in Adelaide??
Cheers,
Steve
Hahaha i'm looking for a similar thing and i just got back from a holiday in Adelaide myself (i'm from Perth). I am just about to call my local auto electrician because my friend said that they stocked new VS lights so i am assuming they will have the harness as well.
My problem is that one of my rear tail/brake lights is intermittent and i have restricted it to a dodgey connection within the bayonet somewhere.
If your local auto electrician does not stock it i would try some holden wreckers in your area.
Hope this helps.
Catchya later.
I have been phoning around, Wreckers wanted $38 per side and I just got the 2 complete looms and bulbs direct from Holden for $70... Go figure......
Thanks 4 ur help :0)
happened to me the other day.....got a harness from my wreckers for 10 bucks. it did turn out to be a vt series 1 harness so it had the clear indicator bulb instead of an orange one. cost like 3 bucks for a set of new bulbs!
hope this helps...![]()
I had to replace mine, $34-36 each brand new from Holden spare parts. No point fitting second hand, only going to be brittle like your originals.
Adam.
