Results 1 to 11 of 11
Thread: Squeaky Breaks
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Default Squeaky Breaks
    Hi All
    I just finished replacing the rotors and pads on all 4 ends. That was front 2 weeks and rear 1 week ago. Before they were screaming and needing replacing so I save a tone doing it myself. (Pretty straight forward and hard to do wrong) . Now I am not a heavy breaker but I do drive in pretty heavy traffic to and from work. I am finding that my breaks are still a bit squeaky and can be quite load at some times. What I was wondering is this normal for common. If any help I just used standard rotors and some Ferado brake pads. Also I was thinking of some solutions already and I wanted some opinions of whether or not those spray on things are any good or not and if there just a quick fix. Any help would be great.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did you bed them in?
    Visit my Facebook page
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    I followed the standard breaking in instructions which was accelatre to 60 break relativly hard to 5 then accelerate rinse and repeat a few times. Also may be a strupid thing to ask what do you mean by beding them in?
    VX Series 2
    Dec 2008
    Canterbury Area, Sydney
    I would of driven to 40km brake hard and repeat at least 5 times. Bedding them in means your meshing the new pads with rotors to make sure they contact properly, secure and wear evenly. If you did'nt bed them in properly then they'll stay noisy until your next pad replacement
    If its not working, you're not hitting it hard enough.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Squeaky pads - I've found have been the $30 jobs from sprints. I have 2 set almost new sitting in the shed.
    I now fit $70 units from a brake place - for the Vn's that is.
    and 3 Dangerous non ABS VN's
    vt s s1
    Mar 2009
    Did you put any brake quiet on?
    Not the backingplate rubbing aainst rotor or anything?
    '01 VU Ute, Manual 5.7
    Nov 2008
    mine has started doing something like that. brakes have only been on for a couple of months and now when i brake very softly there is a rubbing sound until i brake sort of hard. getting it serviced soon, should be right.
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    Just an update since this was a couple of weeks ago. it all seem to be fine now it just seemed that it took longer to break in then what I thought. We at least this weekend i have my new twin cat 2.5" cat back system to install this weekend. So looking forward to that
    2000 VT S Tiga Mica
    Jun 2008
    vic,melbourne
    i always spray brake clean/degreaser type stuff on the rotors when you get them to take off that coating that's on them, and i use "anti squeak" spray on the back of the pads and i have never had a problem....only one time i have had squealing brakes and that what because i used a cheap brand pad, i use Bendix and they work 150% fine all the time every time for me,
    VY SV8
    Sep 2008
    fit bendix graphite pads, not sure on the product number but mine were really bad and i got told to deglaze my rotors 350$$ at holden, ended up buying new slotted rotors and bendix pads only to take the rotors back because they stopped squelling after a good clean and new pads. F*** paying 350$$ when i can get new ones for 400.
    vx commodore v6
    Jun 2009
    rowville
    yeah it would of be your brake slides you need to give them a really good clean.
  1. My breaks work better in the wet????
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2011, 06:14 PM
  2. Cigarette Breaks :|
    By 1991_Vn2nV in forum The Pub
    Last Post: 08-12-2008, 03:32 PM
  3. squeaky breaks VX
    By InnocentMJ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2007, 11:24 PM
  4. VE HSV breaks five second barrier!!!!!!
    By batemada in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-08-2006, 01:32 PM
