Results 1 to 8 of 8
Thread: Driveline Shudder
    vt s s1
    Mar 2009
    Default Driveline Shudder
    Few weeks ago changed the diff oil in my vt with 75-140.
    Anyway it was actually quite noticeb;e the difference but now i have the feeling my diff is locking up.
    When go at rolling speed and turning the car theres a noticeable knocking sound from the rear.
    Seems to be getting more severe and getting a bit worried.
    When i did the oil i forgot to add the addative would this be the reason?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I use this stuff:
    100% Synthetic 80W-140 Heavy Duty Limited Slip Differential Oil - Nulon Products Australia
    It's got the additives in it already, so you don't need to worry about that.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Sounds like it could well be. If it's an LSD then drop out the oil and put in the right stuff before you wreck it completely.
    vt clubsport 5L 195i
    Apr 2009
    brisbane
    Quote Originally Posted by danja View Post
    I use this stuff:
    yep i use this stuff in my clubby 2!great stuff....it will fix the problem no worries as did mine...
    vx commodore v6
    Jun 2009
    rowville
    Ive had the exact same problem and im sorry to tell you this but its your center bearing in your tail shaft its got nothing to do with you diff oil, if you dont fix it your center bearing bracket wil snap and could brake you hand brake cable thats directly above it.
    does it sound with the noise is coming from under the back seat floor?
    it pretty cheap to fix i picked up a new tail shaft for $80 its simple to fix just takes a bit of time
    you will need a size 18 reverse torx bit aswell
    mx kid's Avatar
    mx kid is offline 5th pinned
    VXII CLUBSPORT
    Apr 2009
    Perth, WA
    sorry to dig up an old thread but im getting worried about my diff.
    i have the same shudder an my VX clubsport. most noticible at low speed in 1st or 2nd.
    it seems to be getting worse. you can hear things grinding and it shakes the whole car.
    i had my lsd cones de-glazed about a week ago and thats when it started. have since taken it back to the diff place.
    the guy didnt wanna test drive it again but told me that its normal and it should go away after 500kms.
    im not convinced.
    any suggestions?
    VX lumina
    Jul 2008
    SE Melb
    get a second oppion in another shop.. then charge the original installer the "inspection fee" if its faulty.
    you got to remember.. alot of shops will say nothing wrong because then they have to fix it and they dont get paid for it.
    so if it does fail.. they will try to blame you for abusing it or something.
    mx kid's Avatar
    VXII CLUBSPORT
    Apr 2009
    Perth, WA
    cheers mate
    i think ill take it somewhere else this afternoon
  1. VS driveline into VN
    By combatantsomeone in forum V6 Development And Modification
    Last Post: 30-04-2009, 03:44 PM
  2. VT Driveline shake
    By Tsunamix in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2009, 06:23 PM
  3. Vn Driveline Backlash
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 05:32 PM
  4. Driveline Vibration
    By DaveJ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2009, 07:38 PM
  5. VN Driveline into VK
    By Pav in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2008, 10:16 PM
