Results 1 to 5 of 5
Thread: Difference between VT & VX SS LSD
    VX II SS Ex Chaser V8
    Jul 2005
    Default Difference between VT & VX SS LSD
    What is the difference between a VT SS LSD and a VX SS LSD, the guy mentioned the yoke was different. Forgive my ignorance, but what part is the yoke. Can I take it from my VX diff and replace the one off the VT so it fits my VX?
    Will the VT SS LSD fit my VX SS.
    When everything's coming your way, you're in the wrong lane.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    The joke is where the tailshaft meets the diff.
    On a VT, it is a 4 bolt metal yoke that connects the tailshaft to the diff.
    On a VXm it is a 6 bolt rubber yoke that connects the tailshaft to the diff. 3 bolts from tailshaft to yoke and 3 bolts from yoke to tailshaft.
    The reason for the rubber yoke was to absorb some of the initial stress on the tailshaft and diff when you give it the beans.
    I think the easiest solution for mounting a VT diff in a VX or vice versa, is to replace the tailshaft to match the diff. My understanding is that to swap over the yokes is more difficult as you need the correct pinion for it aswell. Not sure about this though.
    Hope that helps
    Jul 2005
    Thanks Jesterarts, I will wait for the right diff. Pain in the butt though.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The LSD part of the diff is the same. Just change the yoke.
    Visit my Facebook page
    vx_ss_black's Avatar
    vx_ss_black is offline phantom vx
    vx ss
    Aug 2008
    campbelltown
    i reckon your probably right in saying youll wait for the right diff. that being said, theyre both pretty ordinary diffs
  1. Difference between FE1.5 and FE2?
    By Utester in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-08-2010, 06:10 PM
  2. Difference between S2 and S1
    By mulligan-can in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-06-2008, 03:53 PM
  3. what's the difference with VZ SS and VZ SSZ??
    By miniac_beater in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-01-2008, 06:57 PM
  4. 97-00,vt-any difference
    By dazlb2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2006, 03:13 PM
  5. Difference between LS1 and LS2?
    By jvp007 in forum General
    Last Post: 05-11-2005, 12:16 PM
