Results 1 to 8 of 8
Thread: Vt with Ve SS rims
    VT Berlina S1
    Jun 2009
    Default Vt with Ve SS rims
    Vt with Ve SS rims
    hey guys was wondering if these are a direct fit or the rims need to be machined?
    also is 600 a good price the come with tyres 2 with 80% tread
    cheers Luke
    VT Calais V6
    Aug 2007
    They need machining as the stud pattern is slightly different. You can buy VE rims that fit VTs
    Vx S pack m5
    Sep 2007
    keilor down, vic
    iv head some on the forum that you can get them machined for $160 or something.
    PORT3R's Avatar
    PORT3R is offline WTB: 1 money tree
    5L VQ stato
    Dec 2008
    Melbourne, Vic
    I didn't need to get mine machined
    Quote Originally Posted by stocky View Post
    anyone got any special tricks for removing a screw that doesnt want to turn?
    Quote Originally Posted by Sphinx View Post
    I recommend explosives.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by PORT3R View Post
    Really? They were already m/c or you bought imitations or they are held on by glue or something?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by Holdens Rule View Post
    Stud pattern is exactly the same. Stud hole diameters are different as teh VE uses 14mm studs and the VT-VZ uses 12mm studs from memory.
    The centre bore may need to be machined... can't remember...
    Acutally... yes i can... :P
    Quote Originally Posted by Jesterarts View Post
    How you going mate... first up... any type of space or adapter is a big no-no... they illegal and in alot of cases fairly dangerous when you get the dodge ones.
    Right... back to your main issue...
    My understanding is that, the VE and the VY DO share the same stud pattern (5x120) but they do not share the centre bore or studs.
    I know that the 12mm stud was used on the VY while the VE has a 14mm stud. So you need to be careful with the nuts you use.
    Found this also:
    Holden VE Commodore: production line at the Elizabeth factory in Adelaide.
    When Holden introduced the all-new VE Commodore in August it changed some crucial dimensions of the wheel-locating system. This was done to avoid confusion on the production line (as the Holden factory will be building both new and old models for some time yet) and to cope with the new Commodore's extra weight, width and grip levels.
    Holden sent the following statement to Drive on Wednesday: "Fitting VE wheels onto a VZ [or earlier model Commodore] is not recommended or condoned by GM Holden as it raises some safety concerns as there are two major differences in the wheels."
    Holden said the VE Commodore has 14mm wheel studs and earlier Commodores have 12mm wheel studs.
    "If a VE wheel were fitted onto a VZ [or earlier model Commodore] there is a concern that there would not be enough bearing area under the retention nut on the aluminium wheel, which, worse case scenario, means the wheel could potentially fall off."
    And also this thread:
    VZ vs VE offset
    Hope that helps.
    Hope that helps
    PORT3R's Avatar
    5L VQ stato
    Dec 2008
    Melbourne, Vic
    Reaper
    They are genuines lol. Didn't need to get them changed at all, they just bolted straight on. I wasn't even aware that they might have been needed to be machined. They may have already been machined, but I don't know
    Dave.
    VL
    May 2009
    they must of been machined theres no way they will fit, the center bore is the only thing that needs to ba machined, to fit pre ve they need to be slightly bigger 1-2mm
    - --FS - SI VL Calais Turbo (no Motor) Good Project -- -
  1. Replies: 0
    Last Post: 31-03-2009, 12:43 PM
  2. [VIC] VS GTS rims -- GTS-R lookalikes (genuine HSV GTS rims)
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 24-03-2009, 09:45 PM
  3. [NSW] WTB: VE SSV Rims - swap for vy ss 18" rims/tyres plus cash
    By pepstar87 in forum Swap / Wanted to Buy / Trade
    Last Post: 24-03-2009, 03:04 PM
  4. Genuine Rims vs Fake rims
    By drewins in forum General
    Last Post: 12-02-2006, 09:55 PM
  5. fs: wh statesman rims + vt berlina rims
    By bennyballbag in forum Parts And Other Items For Sale
    Last Post: 20-01-2006, 03:55 PM
