Results 1 to 9 of 9
Thread: vx L67 idle problem
    Genuine HDT VN AERO no 20 of 78
    Mar 2006
    Default vx L67 idle problem
    it is idleing rough but driven its fine have had all the gaskets replaced in the motor hoes the lot am thinking i need the injectors done what could be wrong coils are fine new plugs been done
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Has it been idling bad since the new plugs? Possibly bad plug, when was spark plugs done?
    VY SII HBD Calais L67
    Dec 2006
    You said it has all new gaskets? Assuming work has been done recently check the vacuum hoses under the throttle body, back of the heads from one head to the other. These are hard to see and alot of people get it wrong at reassembly.
    VYII Calais L67
    Mar 2006
    yeah i had the velly cover gaskets done 2 sets of plugs put in charger gaskets new vac hoses the works the mac recons its the injectors
    Dec 2006
    Whay would the injectors affect the idle all of a sudden if they were fine before the job was done? It will be something that was not re fitted 100% during the job. Plug leads or vacuum hoses are my tip. Injectors will be fine
    VYII Calais L67
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    i had a fair large vacc leak from around 2 of the injectors - shagged O rings... it would bounce from 500-1100 rpm
    Mar 2006
    il give it a shot 2morrow and get bk 2 ya it is doing a bit better than when i 1st picked it up
    VS l67 statesman
    Dec 2008
    When mine has this problem I usually trace it to shit fuel ,it seems to be very sensitive to it
    Mar 2006
    its had 2 different fuel jonts i put 10L lots into it i am over it checked all the hoes all seam ok
  1. VT SS 6.2L idle problem
    By brooksie81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2009, 08:00 PM
  2. Air problem at idle
    By tyrefryer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2009, 08:43 AM
  3. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  4. Idle problem
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2005, 04:24 PM
  5. Idle problem
    By DISTURBED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2005, 09:26 PM
