Results 1 to 5 of 5
Thread: VT Commodore - Broken Ignition Barrel
    1999 VT Commodore
    Jun 2009
    Default VT Commodore - Broken Ignition Barrel
    I would really appreciate your help with a broken ignition barrel in my girlfriend's 1999 VT Commodore. The engine wouldn't crank and the ignition key would turn on accessories but then go the rest of the way with no resistance. I worked out that the die cast barrel locator had broken in the ignition so I attempted to separate the ignition switch from the key barrel
    and start with a screwdriver. I did get the ignition to turn however the car still won't start. My girlfriend rang a Holden centre who said it had something to do with sychronisation. I wondered if there was a tamper proof system in this model which was stopping the car from starting. Any ideas?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The key needs to touch the key reader around the ignition to disable the immobiliser.
    MY RIDE
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    best thing, keep jiggling the key giving it small taps from the end and try to turn it into the ON position, from there you can pull the shrowd off, slip a pin down into the barrel release and pull out the ignition barrel.
    also... if your in a tight spot and cant get it to start, put the key into the ignition and you can actually START the car by manually turning the ignition switch on the other side of the steering column of which the barrel ends and where the shaft of the barrel turns the ignition switch
    ive had a bit of exp with ignition barrels so far with my VX... ive been thru 3 in the first year of getting her lol
    petersmith is offline Banned
    vt
    Jun 2009
    mine did the same thing needed new barrel
    take it out give your key to locksmith they charged me 50 bux for new one cut and i put it in
    some little pin inside snaps letting you turn key right round over and over
    98 VT Commodore Acclaim options
    Mar 2010
    Yep, mine snapped too. Twice in 12 months so I bypassed it. Check out my other posts for info n pics.
  1. vh ignition barrel
    By TUK20Z in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-06-2009, 10:49 PM
  2. Ignition Barrel
    By jonathon_86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2006, 02:01 PM
  3. Broken ignition barrel help!
    By rufion in forum Electrical Wiring / Questions
    Last Post: 11-11-2005, 05:22 PM
  4. How to remove ignition barrel VN commodore
    By Trevornicole in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 05:14 PM
