Results 1 to 12 of 12
Thread: Help? Passenger side door handle doesn't lock
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Default Help? Passenger side door handle doesn't lock
    Hey All,
    Tried the search tool with no help for my particular problem so I ask the JC gods for help... lol
    Basically my passenger side door handle (external) is not working.... but the inside handle is.... The actual locking mechanism also seem's to jam sometimes and not allow the door to close as per normal (need to fumble with the outer look to get it to securely close the door...
    Has anyone else had this issue and can someone please help!
    (Apologise for sounding like a n00b!)
    Thanks in advance...
    Rich
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    My mate has had this happen to him (has lived with it for around 6 months & its on the drivers side) i determined the problem is a broken latch where the metal rods goes up when you pull the handle up from the outside, all you have to do is get a new door outer door handle bit and get it repainted. Although your problem sounds the same it could be a different latch that is broke i would take the door trim off and inspect door handle.
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    Cheers bud, already confirmed the external is fine, so it may be the locking mechanism itself... Anyone else had this issue?
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by rch-13z View Post
    You said when you try your external it does NOT work, i still think its what i described, Where the metal rod clips onto the inside of the door handle is broken
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    Quote Originally Posted by SMIT View Post
    But when I pull the outer handle the metal rod that goes further down does move... Therefore not being the external handle....
    Pretty sure I've been given the answer off another forum which was that my "actuator" is buggered... Pretty common supposedly for VT-VZ...
    Will have another fiddle on Monday.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Ive re-conditioned my locking mechs and apon accident the door would not close (lock was jammed)
    The actual mechagnism flips around and jams the door. A screwdriver flipping it back fixed it.
    Might also just be sticking and need to be dry lubed.
    Or the striker has moved. Check the paint around the striker to see the difference in colour and if its moved.
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    ive got the same problem on my VX, think it the actuator also, as when you manual lift the lock up the external handle works, maybe there is some way of adjusting the actuator up higher therefore pushing the lock up higher? i dont know havent even had a look in side yet. ideas anyone?
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    There is a stupid little plastic bit which hangs off a thread coming from the door handle...
    Being plastic and hollow it bends and no longer engages the looking mechanism.... Basically $2 from Holden and adjust it right would have fixed my issue....
    Replaced the actuator anyways as it was abit rubbishy when I took it out....
    Jun 2009
    qld
    sweet mate, thanks for sharing the knowledge, i have just been putting up with it, it only the mrs side anyway lol
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Hey Rich do you still have your old handles?
    If so would you sell just one passenger side handle?
    I snapped my passenger front yesterday
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    yeah dude, PM me your address and I'll send it to ya on Monday....
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. Passenger Door Handle Replacement
    By hughsy76 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 11:44 PM
  3. Broken door handle with child lock on
    By Psycho in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 08:34 PM
  4. Broken passenger door lock
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 03:01 PM
  5. Door Lock Handle: how to remove?
    By Lord-Data in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2004, 02:08 PM
