99 vt v6 runs beautifuly, normaly starts sraight up, drives like as dream... but every now and then if the engine doesn't catch sraight away it just wont start unless i keep blipping the starter, up to maybe 20 times - eventually it will catch and run fine. one time it stalled and i had to pull over and perform above to get going.
not heat affected. niether cold or hot start. truly intermittent. fuel pump primes as normal. key buttons work fine. been thru forum search already.
Any ideas guys?
Sai Dai Tae Ma Damies!
there's 100's of threads like this but ill say it again, Crank Angle Sensor 99% sure
yeah ive trawled thru hundreds of threads like this searching for answers, thanks anyway! Obvious diference as far as i can tell is that this will occurr from cold as often as hot... tho it hasn't even had a problem for a couple of weeks now...
Im reluctant to fork out for a three arm puller and a new CAS if it's just to rule it out... and if there's something else that can cause this then someone on here will know about it!
do you mean it will just turn over and not start?
almost sounds like your saying the start wont engage..
My commodore did that to me for about 3 weeks mate. The problem was the starter motor!
Yea it just turns over and doesn't start, starter motor engages and spins nice and fast, but if the engine doesn't fire up in the first second then it simply wont fire unless i sit there turning the key repeatedly (glad i have a good battery), eventually it will get over itself and fire up and run as if nothing happened.
the next time it does it i will check for the imobiliser light, aparently the bcm can loose it's sanity and not cancel the imobiliser - but i wouldn't think the fault would be intermittent like this - one week it did it three times, but hasn't done it in 2 - three weeks.
Sounds a lot like a dodgy immobiliser circuit in the key head, I had that problem intermittently and a new key head solved it completely.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
starter and crank angle sensor one of thos two
I have the same problem with my 97 VS. have you had anyone check it out yet? if so what was it?
take car to car fixy place....1 right answer beats 100000000000000000 wrong answes
