Just bought a second hand supercharger kit off a commodore to put in my vx came with ecu etc, just wondering if its going to damage a stock motor?
m90 charger?
yeah its the M90 charger
yeah its the m90
what did you get in this kit?
to put the blower on, youll need either l67 heads or a manifold to suit the charger and an ecotec
injectors are a must also
with a good tune the bottom end should hold up fine to stock boost of 6-7psi
Supercharger, ECU, Fuel rail & injectors, Alternater, Throttle body & intake, airbox & air duct, pulley tensioner with cooling line & 2 belts
I don't know the exact figures but the supercharged models ran a lower compression. I think the L36 (ecotec) had about 10:1 while the L67 (supercharged) has 8.5:1.
Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
Don't be stupid. Power isn't measured by the size of your tacho
well youll need the balancer to run the puller to start with from memory theres a few extra pulleys
that the pully setup as standard..
so you dont have the valley?
i got the extra pulleys but i think i need to get the manifold for the s/c to sit ontop?
thats right mate... you can either get a valley thats made to bolt to ecotec heads or just get l67 heads
personally id go with getting a whole top end from a l67
do you know where i can get l67 heads from melbourne?
Yella Terra sell them
