hi guys just wondering if a supercharged v6 and gear box will fit in to a vt commy do i have to change any thing also cos it has direct injection gas system i need to swap computers will this work also look at puting the lsd diff center out of the vs into my vt
only doing all this work cos i got this vs dirt cheap motor a1 condittion also will have a compleat vs calias interior and abs system for sale soon also like brand
new thanks guys
Hi mate, welcome to the forum
the S/C motor and box will bolt into your vt fine. u will have to use the loom and ecu that came with the new s/c motor..
does the new engine have the gas setup or ur current setup?
In regards to the diff, there is one thing u'll have to check on ur diff first before its a straight swap. check where the tailshaft bolts to the diff yoke. if it has 4 bolts the VS LSD will bolt up fine.
if yours has 3 bolts, you have the newer style diff and its a little fiddly getting the VS diff to work, but not impossible. you can get the yokes swapped and it should be ok. but please check with a diff specialist.
